Author Topic: telematic unit help  (Read 2610 times)
bow123
  • n.ireland
    • 03 vectra c sri
telematic unit help
« on: 01 April 2013, 09:27:19 »
i have a telematic unit with the ncdc 2015 retrofitted to my vectra c what mic do i use with this unit and what is the 6pin plug beside the 32pin plug does a mic or something plug into that
Re: telematic unit help
« Reply #1 on: 01 April 2013, 12:11:44 »
The Omega ones use the Mic fitted in courtesy light. Veccy may be different.
Only needs 32pin plug, and cellulare antenna :y
    • 530D M Sport, 330i Coupe
« Reply #2 on: 01 April 2013, 15:40:57 »
Vectra C Mic is in the courtesy lamp as well but it's a different style to the Omega one.
bow123
  • n.ireland
    • 03 vectra c sri
« Reply #3 on: 01 April 2013, 19:02:51 »
wonder what type of mic it is using for it has to be wired to the 32 pin plug of the telemantic
« Reply #4 on: 01 April 2013, 19:06:19 »
The Mic just plugs into a loom plug at the Courtesy lamp end  :y
bow123
  • n.ireland
    • 03 vectra c sri
« Reply #5 on: 01 April 2013, 19:09:09 »
i retrofitted the ncdc2015 so i will not have the wiring i would take it
bow123
  • n.ireland
    • 03 vectra c sri
« Reply #6 on: 01 April 2013, 19:18:39 »
PIN 1 - 2 - 17 SEEM TO BE FOR THE MIC THIS IS THE WIRING FOR THE TELEMATIC UNIT THERE SEEMS TO BE 3 WIRES FOR THE MIC
Pin 1 - Microphone signal
Pin 2 - Shielding (assuming for the microphone wires)
Pin 3 - Handset connector pin 3
Pin 4 - Nav system control line pin 35
Pin 5 - Nav system control line pin 36
Pin 6, 7, 8, 9, 10 - Not connected
Pin 11 - Medium Speed CAN - High (nav system pin 32)
Pin 12, 13, 14 - Not connected
Pin 15 - +12v constant voltage FI1, 20A
Pin 16 - +12v constant voltage FI1, 20A
Pin 17 - Microphone signal
Pin 18 - Handset connector pin 1
Pin 19 - Shielding - Handset pin 4
Pin 20 - Nav system (Antenna Amplifier - looks like Navi Pin 7)
Pin 21 - Handset connector pin 5
Pin 22, 23, 24 - Not connected
Pin 25 - Airbag ECU pin 15 (looks like an airbag deployed signal)
Pin 26 - Diagnostic port - pin 8
Pin 27 - Medium speed CAN - Low (nav system pin 33)
Pin 28, 29, 30 - Not connected
Pin 31 - Ground
Pin 32 - Ground
« Reply #7 on: 01 April 2013, 19:33:12 »
It's pins 1 and 2. The other Mic connection is for a privacy handset.
« Reply #8 on: 01 April 2013, 19:57:38 »
Close. It is adjacent pins, but its 1 and 17 for the MIC
Pin 2 is the shielding (for MIC). As it runs up the A Pillar, the cable goes from 2 wire screened to just 1 wire screened, thus the shielding is used at that point :)
bow123
  • n.ireland
    • 03 vectra c sri
« Reply #9 on: 01 April 2013, 20:11:28 »
so if i am to use a 2 wire mic what pins do i need to use the wiring is not in my vectra i am retrofitting this
