Author Topic: xenon bulb  (Read 1630 times)
manolo
xenon bulb
« on: 02 April 2013, 09:02:24 »
Hi,
right xenon on omega 2.6v6 2002 stop working  >:(
Do I have to take off headlight to change the bulb?
What type of bulb is fitted?
I presume that the original is pretty expensive, and thinking about buying from Ebay...
Thanks
Simon.rose1
  • Walsall
    • Omega 2.5v6 cdx
Re: xenon bulb
« Reply #1 on: 02 April 2013, 09:26:29 »
Best place to get them is from here http://www.hids4u.co.uk/ you don't have to take headlight out just cover from back of headlight to access bulb dontbtouchnthe glass of the bulb though
Re: xenon bulb
« Reply #2 on: 02 April 2013, 16:41:12 »
Assume to have HIDs - if so you want DS2 bulb.
Bit tight access but ok to change without removing light unit - allow 1/2 hour from swithching off lights/ignition before starting, undo 3 x torx screws on back, and pop bulb out.   :y
Spireite
Re: xenon bulb
« Reply #3 on: 02 April 2013, 17:25:16 »
D2s bulb
Philips were standard fit on those, I paid £61.99 recently from autobulbsdirect 3 weeks ago for a pair.
kevinp58
  • kent
    • 2002 3.2 elite
Re: xenon bulb
« Reply #4 on: 02 April 2013, 17:25:37 »
Hi It is better to take the unit off the car as it is very tight and the plastic crappy adjusters will probably break  >:( so be very careful and try not to use alot of pressure otherwise you will be taking headlight unit off and either replacing it or the adjusters inside.  ::)
Re: xenon bulb
« Reply #5 on: 02 April 2013, 22:42:26 »
Replaced 2 on my old Elite and 1 on the old Estate - all without removing light units - as said a bit tight but not a problem.
