Author Topic: AR35 into a TD  (Read 1507 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
AR35 into a TD
« on: 03 April 2013, 11:11:27 »
Quote from: Shackeng on Yesterday at 14:18:47
    Hopefully putting in the AR35 box this w/e which I have had for at least 3 years. Then the full fat chip.
    A thought occurred this AM, (I have about 1 a day). What difference will the Sport mode make when the full fat chip is fitted? :-\
Quote from TheFatShadow
If you have the latest gearbox ECU, don't need sport. Can't remember if I used sport mode much on my old tractor...  ...used to lock it in 3rd a fair bit to stop the 3rd/4th constant hunt at around 50mph.
I am a bit confused about this. Should I be fitting a different ECU to the new gearbox before fitting it this weekend? If so which one will I need?:-\ :-\ :-\
unlucky alf
  • worksop, notts
Re: AR35 into a TD
« Reply #1 on: 03 April 2013, 18:50:20 »
I suppose it depends on what type of g/box ECU you have fitted to begin with, I believe the later TD's ECU is totally different to the early ones connection & size wise, Ive got a suspicion that the later ones can be loaded with the later g/box software whereas the earlier ones cant, Or thats what TB said to me anyhow ::). Just been thinking further & I do remember that the G/box ecu has to be the same year/number as your original anyway, So if you are lucky enough to have a later type then just get the software updated. :y
« Last Edit: 03 April 2013, 19:07:47 by unlucky alf »
Re: AR35 into a TD
« Reply #2 on: 03 April 2013, 19:56:06 »
Nothing to worry about Shack.
If yours is a 1998 or later car, it can be flashed up to v9. Whether or not its worthwhile on a tractor, not sure - mine did about 50 miles before I flashed it, so really can't remember how bad it was...  ...bad enough to annoy me enough to do it, clearly, but still wasn't like a v6 gearbox for smoothness
Shackeng
  • Ramsbury
Re: AR35 into a TD
« Reply #3 on: 03 April 2013, 20:59:47 »
The one going on was refurbished in 2005, and has only done about 10,000 miles since. My car is a 99 MFL TD. :y
Re: AR35 into a TD
« Reply #4 on: 03 April 2013, 21:08:06 »
Yup, fear not, slap the new box in.
You can upgrade the TCM firmware, but as previously said, not sure its worth it.
Re: AR35 into a TD
« Reply #5 on: 03 April 2013, 22:36:38 »
this :y
