Author Topic: TD gutless, no kickdown, any ideas?  (Read 4411 times)
Agemo
  • Cleethorpes
  • Insignia
« on: 03 April 2013, 17:25:54 »
As title really, the tickover was a little slow, so I decided to clean the MAF sensor (carefully), not much dirt in there, so plugged it back in, car runs OK. On driving it, there is a definate loss of power, and no kickdown at ALL. Codes are:-
64, 85, 96, & 92, but all these were present yesterday when the car ran OK.
Anyone got any ideas?
Agemo
  • Cleethorpes
  • Insignia
Re: TD gutless, no kickdown, any ideas?
« Reply #1 on: 03 April 2013, 17:48:01 »
OK, latest is I disconnected the MAF, and the car is responsive again. I also have code 88 (Air Mass Flow Sensor Voltage High) so it looks like I an in need of a MAF sometime.
hoofing it
« Reply #2 on: 03 April 2013, 17:58:49 »
I'd be cleaning out the vac pipes as well mind don't take them all off at once if you mix them up the car won't run well (been there done that ;D).
The vac pipe to the underside of the inlet manifold around num3-4 injector tends to get full of old oil and carbon deposits :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 03 April 2013, 21:36:51 »
Thanks for that, good idea.  :y
« Reply #4 on: 03 April 2013, 21:42:16 »
Suspectbyou destroyed the maf by cleaning it
Agemo
  • Cleethorpes
  • Insignia
« Reply #5 on: 04 April 2013, 08:45:03 »
I can't believe I did any damage, just a gentle wipe inside with a rag, but I suppose these things are delicate (on purpose???)
I may give it a spray with carb cleaner & see if it works, but a new one will be the best option.
« Reply #6 on: 04 April 2013, 08:49:38 »
That will really kill it  :)  :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #7 on: 04 April 2013, 13:38:27 »
Oh, won't bother trying that then, thanks for the tip.  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 04 April 2013, 14:30:31 »
In that case dont let Suspectbyou near your car again  ;)
Agemo
  • Cleethorpes
  • Insignia
« Reply #9 on: 04 April 2013, 14:37:10 »
How would I know it was him? He keeps changing his identity!   ::)
jonnyboyws6
  • grimsby
« Reply #10 on: 04 April 2013, 16:07:09 »
Pretty sure I've got one kicking about if you want to try it see if it runs any better?
Agemo
  • Cleethorpes
  • Insignia
« Reply #11 on: 04 April 2013, 16:09:27 »
Hello Mate. I never thought about you, yes I can collect it today, let me know when you are in.  :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #12 on: 06 April 2013, 22:40:26 »
MAF collected, thanks jonnyboyws6, I owe you one. Will fit as soon as I can.  :y
