Author Topic: Coolant Temperature Sensor Part Number  (Read 1717 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 04 April 2013, 11:23:03 »
Hi guys,
As above I'm at work at the mo and can't get to my TC log in details. Anyone know the part number for the above? Would be a great help - cheers  :y
RIP Paul Lovejoy
amba
  • Medway towns
    • German V6
Re: Coolant Temperature Sensor Part Number
« Reply #1 on: 04 April 2013, 12:07:09 »
Think the one you are after is ...90510183..fits onto the coolant bridge with the blue end  :y
Webby the Bear
  • Northampton
« Reply #2 on: 04 April 2013, 12:33:49 »
Cheers Amba. Legend!!!  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #3 on: 04 April 2013, 12:44:25 »
ps when I fit this bad boy I take it theres nowt to it other than unscrew old, screw in new?
also am thinking a tiny bit of copper anti-seize on the threads. agreed?  :y
RIP Paul Lovejoy
« Reply #4 on: 04 April 2013, 12:52:37 »
Yes!  :y  :y
You'll need a note off GixerChris if you do  ::)  ::)
amba
  • Medway towns
    • German V6
« Reply #5 on: 04 April 2013, 13:29:39 »
Wouldnt trouble with copper slip as its not going to be a part that you are removing on a constant basis and being it is an open chamber to the water way you don,t want bits of that circulating in the coolant.
Fit it dry is my advise and don,t go crazy when you tighten it up. :y
« Reply #6 on: 04 April 2013, 18:42:18 »
Might have a 2nd hand one here Webby if yours is shagged. That said, probably not worth the petrol to get it.
Webby the Bear
  • Northampton
« Reply #7 on: 05 April 2013, 21:04:32 »
Soz TB, didn't see your reply until now.
Thanks for the offer but I have bought one already... only £11 on TC  :y :y :y
By the way mate, I remember you saying you sometimes popped in to Northampton to go to Vauxhall..... the one in Kingsthorpe isn't there anymore... its moved to Riverside (I found out the hard way  ::))
RIP Paul Lovejoy
