Author Topic: wiring diagram  (Read 4529 times)
scottambrose
Re: wiring diagram
« Reply #15 on: 10 April 2013, 14:40:55 »
im going to try and remove the relay for the heated rear window. in the hope that is coming on randomly. any ideas which one it is.
Re: wiring diagram
« Reply #16 on: 10 April 2013, 16:19:24 »
Fuse box under column :y
Open the lid, switch ignition on and turn switch on and off, should jump out at you :y
scottambrose
Re: wiring diagram
« Reply #17 on: 11 April 2013, 10:59:14 »
well is wasnt that. but. the battery has drained again over night and the drain is now showing .41 amps it was 0.03amps. if i disconnect that main 80aqmp fuse on the battery box which is fv5 the drain goes. but i have checked all the fuses in the fuse box and none show any drain other than the door lights( as i had door open) but that goes if i hold plunger in. the immobiliser also runs from that circuit i think so that must be the culprit. but how can i test it. ive also unplugged every relay in the fuse box and the box next to the battery and it still showed between .41 and .35amp
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: wiring diagram
« Reply #18 on: 11 April 2013, 11:27:03 »
Time delay relay for the rear fag lighter is a common place to start  ;)
scottambrose
Re: wiring diagram
« Reply #19 on: 11 April 2013, 11:36:48 »
nope that works as it should ive left a small usb charger in it with an led and that goes out after a while and comes back on when you unlock again. i just joined the wires back up for the boot mod i did and unplugged the plug from the box in the footwell it goes into and the drain has gone back to 0.03 amps then unjoined the wires again as it was before and still its at 0.03 amps. which doesnt make sense, the drains now gone. but all i did was touch that box
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
Re: wiring diagram
« Reply #20 on: 11 April 2013, 16:14:03 »
Boot mod?
dbdb
  • west london
Re: wiring diagram
« Reply #21 on: 11 April 2013, 16:17:24 »
Was the .41 amp 10 minutes after the car was closed down or before that?
scottambrose
Re: wiring diagram
« Reply #22 on: 11 April 2013, 16:43:48 »
after 10 minutes. but that was also with all the fuses and relays removed.
scottambrose
Re: wiring diagram
« Reply #23 on: 11 April 2013, 16:44:26 »
i unplugged the central locking control box plugs and then plugged them back in and it went down to 0.03 amps from 0.36
dbdb
  • west london
Re: wiring diagram
« Reply #24 on: 11 April 2013, 17:29:57 »
Just checked mine (remember I pulled the powersounder out) the drain is now about 0.05 amp on my clamp meter.  It's not really precise at such a small range so proably give or take a couple of 0.02 amps.  That's after the car has settled and arming the alarm made no difference.
I'd be happy with that it seems to be within spec but my new battery is currently 12.4V - 72% charged.  I would expect it to be kept higher than that.
Possibly the 0.05amp is rising when I'm not watching.  I have a meter with computer output that can log every second, it would be a hassle to set up but I may try it. First though I keep a manual log of the battery SOC.
What happens to your battery volts if you pull the fV5 fuse and leave it overnight?
dbdb
  • west london
Re: wiring diagram
« Reply #25 on: 11 April 2013, 17:39:31 »
here's a useful chart I made to convert voltage to State of Charge
scottambrose
Re: wiring diagram
« Reply #26 on: 11 April 2013, 19:32:41 »
Voltage drop is minimal without fv5 in overnight ive re charged battery and tested it its fully charged and said 13.2volts but thar was only anhour afterbeing taken off. Il check it again in themorning
dbdb
  • west london
Re: wiring diagram
« Reply #27 on: 11 April 2013, 20:26:51 »
you'll get a surface charge above 12.8V after charging it will soon go when any load is applied. Anything  12.8V or above after rest is 100% SOC.  A kanckered battery could read 13V+ after charging but not start a car mind.
scottambrose
Re: wiring diagram
« Reply #28 on: 12 April 2013, 08:20:48 »
its reading 12.85 volts and starts the car fine, will leave it overnight again and see what it goes down to now its settled.
