what size lpg tank in an estate?
Started by Dazzler, 05 April 2013, 12:26:03
adey2
no ones commented, hows the spare wheel well going to be dropped when the fuel tank is right below it   hth
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Quote from: adey2 on 06 April 2013, 10:45:28
Fuel tank would have to be dropped too.
symes
in mine I got tank same size as spare wheel-42 litre I think? gives me about 100 mile range-not a lot but I go past lpg station on way to work so ok-plus I did'nt have to faf about raising floor-but horses for courses IMO AS it had a 90+ litre cylinder across rear of car behind rear seat as an estate it was useless BUT now can carry all sorts of stuff including Olivias Land rover
Quote from: symes on 06 April 2013, 11:00:19
I make that around 11mpg?
I have a theory with small tanks and/or short fills that they crucify mpg.  Certainly on mine, which average 19 and 17mpg respectively, if I don't wait until near empty before filling, the MPG drops dramatically.  Not sure why this is, as surely the filling gas escape cannot be that much, but others have seen the same.
11mpg!? Even on petrol around town low 20's from a 2.5 should be easily do-able  :-\
Quote from: tunnie on 06 April 2013, 11:33:43
Not everyone drives like you.  On petrol (which gives better mpg than LPG), sub 10mpg is easily possible over a couple of gallons. You really must try harder ;D
symes
I dont run it empty :D actually according to MID I get 21 :y--honestly 11mpg-its a miggy not a challenger ;D ;D ;D
Next time you fill, can you record mileage, then on the fill after, work out MPG. Interested if you see the same with smaller tank as I see short filling my larger tank :y
symes
I have a 73Litre full Toroidal tank in mine, the boot floor is raised by 50mm, still loads of headroom! Btw, the tank fills to 60 litres so no real complaints there either! :y
Oh yes I did ;)
