Author Topic: Clicking/Knoking/Klunking  (Read 3540 times)
grain.ben
« on: 06 April 2013, 09:01:20 »
Got a few niggles I want to sort out next week while im off work.
1> Got a clicking noise coming from the passenger door/ B pillar area. Hard to explain, but imagine a pendulum thats swaying back and thorth and hitting something on each side, now, when i set off, click, and when i brake, click  :-\ , any ideas as its driving me mad, does it all the time  :-\
2> Had a clunking issue ever since i got the car, it clunks and knocks on the front end, coming from the suspension area/ wheels ect. It clunks when going over rough roads, bumps and potholes i cant avoid  :-\ . The funny thing is, when ever i take the front wheels off it stops doing it for a while then comes back (like ive disturbed something  :-\ ). And something else ive noticed, it doesnt do it when its very cold outside, like this morning, but when the temperature rises is happens more! Any ideas?
3> how the hell does the passenger side air vent come off, ive found the guide but it wont come free so i can get my glovebox out  >:(
Cheers chaps, hope you all have a lovely weekend   :y
Re: Clicking/Knoking/Klunking
« Reply #1 on: 06 April 2013, 09:09:47 »
1 brake pad ant rattle sprng broken or poorly fitted
2 wishbone bushes fubar
3 see glove box removal guide
NEXT! ;D ;)
grain.ben
« Reply #2 on: 06 April 2013, 09:15:32 »
NEXT! ;D ;)
1> OK will have a look
2> Not wishbones, powerflex bushes fitted nearly a year ago, TFS had a look at these when i went up to his place last, and said they were fine  ::)
3> Went by the guide but it wont budge and i dont want to break it  ::)
« Reply #3 on: 06 April 2013, 09:32:23 »
NEXT! ;D ;)
2 Rearward vertical bush.
3 av it!
« Reply #4 on: 06 April 2013, 11:48:14 »
2) droplinks worth checking
3) sure you removed the hidden screw?
« Reply #5 on: 06 April 2013, 11:57:49 »
Clunking = Dropliks  :y
grain.ben
« Reply #6 on: 06 April 2013, 12:20:39 »
2> Will have the wishbones checked again and will check the droplinks, i know the drop links are non gm, (had them fitted before i found this this site, not knowing to use gen gm ones at the time  ::) ) They are my suspicion anyway  ::)
3> isnt the "hidden" screw behind the vent?? Its the frigging vent i cant get out unless im not pulling? it hard enough?  :-[
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #7 on: 06 April 2013, 12:24:43 »
have you removed the end cap off dash to get to the screw in question, just pulls off
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
grain.ben
« Reply #8 on: 06 April 2013, 12:30:50 »
Yep, end off, then two screws, one at top, one at bottom, i removed both, the top of the vent moves but the whole vent doesnt want to shift  :-[
« Reply #9 on: 06 April 2013, 12:33:48 »
Look for the retaining clips/tangs towards bottom of vent
grain.ben
« Reply #10 on: 06 April 2013, 12:35:06 »
Cheers chaps, will have a good poke around in the coming days  :y
adey2
« Reply #11 on: 06 April 2013, 12:35:26 »
to remove vent top screw only then pull vent towards door whilst pulling it out its location as a holding tab on side closest to airbag   hth
grain.ben
« Reply #12 on: 06 April 2013, 12:36:40 »
Ahhh i see, ill have a go at that tomorow, taa muchly  :y
« Reply #13 on: 06 April 2013, 12:58:21 »
GM droplinks cost to much.  Febi, Lemforder or Merle HD are cheaper and as good as GM
« Reply #14 on: 06 April 2013, 13:44:23 »
Clunking = * Dropliks  :y
* = possibly! possibly drop links. But given the the other descriptions re temp and jacking, I'm going with bushes. ESP as drop links are a rattle, not a clonk, so much.
But its defo worth checking drop links. Play can be fealt with both wheels jacked. :)
