Any Vectra C specialists
Started by PAULCDX, 08 April 2013, 19:58:02
Quote from: ex taxi al on 11 April 2013, 16:26:21
Yup, minus multirams iirc :y
Cheers for that , gives something different to look at  ;)
henryd
Quote from: EMD on 11 April 2013, 16:29:55
Or of course the 3.0 v6 diesel 8)
other rides
dazzerM
Quote from: Marks Hornby 'OO' on 11 April 2013, 00:38:44
I would expect the motor to run at full speed if its the resistor but not at any lower speeds
That's how mine went only worked on number 4, diagnosed by VX themselves as resistor  :y
Darren
PAULCDX
Seen as my heaters aren't working at all on any speed, scuttle is clear and dry am I still assuming it's the motor that has gone or just the resistor or both?  ;)
PAULCDX
Just a thought, the previous owner last year had a new exhaust from Cat all the way back, could this be throwing up any faults are causing my EML light to come on and poor stuttering idle?
Just wondering whether to take it back to Kwik Fit and get them to check exhaust system as it's still under guarantee?
PAULCDX
Update, heres the codes that have come up which may explain the poor idling and Exhaust emissions light on.
p0170 - fuel trim system rich (11) - present
p0100 - mass or volume air flow circuit low input (06) - not present
p1525 - throttle control malfunction (65) - not present
p1550 - electronic throttle control engine stop (3a) - not prensent
Anybody know of these codes or where to start first?
Thanks as always,
Paul  :y
dazzerM
Quote from: Tall Paul on 13 April 2013, 18:56:09
Thanks as always,
Paul  :y
Hi mate, right bar the exhaust emissions light on I can relate to all bar po1000
I would strongly suggest this is the throttle body at fault as your symptoms are identical to what I had
It's to do withy the electronically controlled throttle control within body, you can hear it click when you turn the ignition on (that's the inlet opening)
I would recommend in the first instance removing the throttle body and giving it a good clean with a brush or similar and some carb cleaner as they can get coked up, whilst off check the function of the body by making sure when you push the plate inside it springs back as it should without hesitation
I am not exaggerating, to this it is a five min job only 2 bolts if I remember rightly,
The other option, diconnect the airflow meter while running And see if it runs differently for code 0100 this may be your afm at fault
It's a shame your not closer  :y
Darren
PAULCDX
To right Daz I wish I was nearer mate, did you cure your Vectra doing what you did mate?
I've been out today and bought another MAF and a throttle body but need to fit to see if any changes  ::)
Cheers mate,  :y
CaptainZok
Most of those codes are showing not present, clear the codes then see what comes back.
TuBy's new whipping boy.
dazzerM
Quote from: Tall Paul on 13 April 2013, 21:04:05
Cheers mate,  :y
Your welcome... I would put money on it running perfect with the new throttle body
Good luck  :y
Darren
#41
Quote from: dazzerM on 13 April 2013, 21:07:53
Cheers mate,  :y
Good luck  :y
If it has been running for some time with duff readings from the MAF and seeing as there is a code for mixture it is extremely likely that the long term trim is miles out.
If you can reset the long term trim you should see an immediate improvement otherwise it may take a while to return to normal (assuming that it ever does - I think the self learning is inhibited if there is an emissions code :-\)
Selseybill
Quote from: Tall Paul on 08 April 2013, 20:47:47
What is alarming is the car has full VX history but no mention of a cambelt change  :o
Car is now on 140k so I'm hoping to god it's at least had one done in it's life.
Thanks for the advice everyone  ;)  :y
My Mig has full Vx service history too. No mentions of cam belt change in the service book either but the print out job receipts go in to more details inc cam belt.
PAULCDX
Those codes were read off OP COM device yesterday so I assume they are still present and my EML is still showing.
If I can get the parts changed I will then get someone to check the codes to see if they have cleared etc.
PAULCDX
Hi Andy, thanks for your input,
So if the parts clear the problem, would I still need someone to adjust the settings on the OP COM etc?
