Garages and their tools
Started by Webby the Bear, 09 April 2013, 20:07:06
Webby the Bear
I like the Halfords pro range of stuff. only time its let me down was getting head bolts out of ralf
RIP Paul Lovejoy
biggriffin
You can get a similar roll cab set up from machine mart for a lot less,with out the picture. :)
Hoof'land storeman.
Webby the Bear
Quote from: biggriffin on 09 April 2013, 20:36:41
this may be a bit lazy but I like the Halfords kit in the carry case....all the t=hand tools you could need right to hand when doing any job. wonder if these are used by any mechanics instead of just DIYers?  :-\
RIP Paul Lovejoy
Generally very pleased with Halfords Pro stuff, yes its built to a price but for what you get is very good and life time warranty.
Only that animal Omegatoy managed to snap a hex socket  ::)
I've also got their big tool chest thing,
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_206443_langId_-1_categoryId_255214
Again feels well made, can't complain really!
doz
We'd all like a Snap on box tool box full of tools. I use Halfords pro range and have so far not had a failure. However I do like Kamaza and when I want some snap on stuff ebay is your friend. Plenty good stuff second hand.
Webby the Bear
Quote from: tunnie on 09 April 2013, 20:40:38
I too broke two T55s  :-[ :-[ :-[ :-[ :-[
That's pretty much the chest I have (a bit older looking but same functions) but a friend gave me it  8) 8) 8)
RIP Paul Lovejoy
CaptainZok
Quote from: STEMO on 09 April 2013, 20:29:12
Quote from: CaptainZok on 09 April 2013, 20:22:14
Quote from: Webby the Bear on 09 April 2013, 20:19:33
now that is what i'm talkingabout - very very noice!!!
You got £2500 lying about spare then Bear?
£2500 for a piece of pressed steel. Kinell.
Yup just like the rest of their kit the prices are crazy.
TuBy's new whipping boy.
Webby the Bear
Quote from: CaptainZok on 09 April 2013, 20:56:06
the school paid £80 a ratchet as a ''well done'' present to 3 of the kids. they could have each had a full 150 piece set for that  :o
RIP Paul Lovejoy
I use the halfords pro stuff , only time i snapped the extension bar was trying to undo omega wheel nuts  >:( >:( >:( >:( >:( fine on any other car  ;D
Webby the Bear
Quote from: EMD on 10 April 2013, 14:27:56
:o :o :o ;D ;D but at least you can get it replaced with lifetime guarantee  :y
RIP Paul Lovejoy
You need to be looking at multiple brands if going Pro and not much of the Halfords stuff will tick that box as the spanners are a bit thin and the ratchets flimsy
I really like the Teng spanners and sockets, Irwin do good vice grips, get a good range of hammers with decent wooden handles then your onto air tools and more specialist
Webby the Bear
Quote from: Marks Hornby 'OO' on 10 April 2013, 14:52:00
That's true about the spanners. Was considering a set of fat flare wrenches to go with the spanners.
RIP Paul Lovejoy
You want a set of offset ring spanners to, the flare spanners will be needed for brake pipes but beware cheap ones as they tend to spread if put under any real load
mantahatch
Probably 90% of my stuff is Britool. I found them to be very good over the years, so much so I gave my son a lot of it when he started his apprenticeship and he is working on plant equipment.
ShameBritool have been taken over by Facom, it is reasonable now but not as good as it once was.
My 3 Britool torque wrenches have been heavily used over the past 30 years and are still going strong. Got to test them on a torque tester about 18 months ago and they where virtually spot on, they only one slightly out was the 3/4 drive by about 1lb. Then it has had some abuse on rather tight stuff  ;) like vw hub nuts.
Quote from: Marks Hornby 'OO' on 10 April 2013, 15:01:26....
My Facom flare nut spanners will spread too  :(
