Author Topic: Is this a misfire (quick video)  (Read 3721 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Is this a misfire (quick video)
« Reply #15 on: 10 April 2013, 19:37:09 »
Webby check the sparks condition.. and there is an obvious air leak..
the plugs you mean cem?  :)
RIP Paul Lovejoy
« Reply #16 on: 10 April 2013, 19:41:01 »
yep..
Webby the Bear
  • Northampton
« Reply #17 on: 10 April 2013, 19:43:12 »
yep..
I've had them out and they look fine mate  :y
RIP Paul Lovejoy
« Reply #18 on: 10 April 2013, 19:45:03 »
yep..
some of them must be fouled if there is continous missfire.. and plus dont use the car in that condition, you will cook the cats with unburnt fuel..
Webby the Bear
  • Northampton
« Reply #19 on: 10 April 2013, 19:45:59 »
yep..
yep, its on drive not going anywhere for now  :'( ill see what its like when ive sorted the vac leak  :y
RIP Paul Lovejoy
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« Reply #20 on: 11 April 2013, 00:02:25 »
watch that second video again, about 8 seconds in looks to me like a large tear in the o/s rubber intake duct near the bottom.  That would give you a lean mix on that side and inbalance, not sure if it would make that much noise but it wouldn't help.
« Reply #21 on: 11 April 2013, 00:28:34 »
Just goes to show, original place for DIS pack is best  :y
lol it ran fine in the new position... its now back and runs shite  ::) ;D
Pull it back out and check the leads are on the diss pack proper  ;D Not sure if should be making that sound though  :-\ Plenum seals leaking  :-\
« Reply #22 on: 11 April 2013, 00:30:55 »
Just rewatched the second vid. Could be on to summat there :-\
Induction noise is normally quite well contained. Disconnect the pipe between the air filter and the MAF with the engine running and see how noisy it suddenly becomes...
Webby the Bear
  • Northampton
« Reply #23 on: 11 April 2013, 10:38:57 »
Thanks guys,
As per the vid i have found one bog vac leak where the breather bridge connects to the throttle body (new o rings ordered).
i'm at work at the mo so cant see the vid. ill rewatch it again asap.
cheers guys, much appreciated
RIP Paul Lovejoy
« Reply #24 on: 11 April 2013, 12:57:03 »
Thanks guys,
bog vac
Webby the Bear
  • Northampton
« Reply #25 on: 11 April 2013, 12:57:27 »
G;day gals, right checked that gash on the bagpipes.... its just a plastic join/seal mark. no gouge  :y :y which im pleased about as i could do without shelling out for a new set  ::) :y
got my new multi meter in the post  8) 8) 8) its a little baby one. so cute. ill post a pic. tested a couple of things. so easy to use as its basic and simple.... like the owner  ::)
RIP Paul Lovejoy
martin42
« Reply #26 on: 11 April 2013, 16:42:51 »
i wonder if you have the ht leads on the wrong way on the coil pack
Webby the Bear
  • Northampton
« Reply #27 on: 11 April 2013, 17:38:48 »
well its defo caused by something. really strange as i'm positive I marked them up correctly. I reckon its more likely to be a HT lead gone TBH as I did swap some round  :y
RIP Paul Lovejoy
« Reply #28 on: 12 April 2013, 11:21:21 »
Didnt you say you you stretched a lead  :-\
