Pages: 1 2 3 4 5 [6] 7   Go Down
Author Topic: rllocks. sat in the rain awaiting greenflag.  (Read 24035 times)
Re: rllocks. sat in the rain awaiting greenflag.
« Reply #75 on: 16 April 2013, 20:04:55 »
For petrol, I'd expect long terms to be pretty much 0%
For LPG, ideally keep them between -10 to +10%
OK .. I'll check them after the Paris trip this weekend on LPG.
Appreciate your teaching :)  :y :y :y
« Reply #76 on: 16 April 2013, 20:06:43 »
If you get a stored trim code, its exceeded 20%. If you get an EML, its gone beyond 23-25% (I can't say accurately, as not that many are that bad)
« Reply #77 on: 16 April 2013, 20:11:14 »
Never seen one of them, only codes I've ever seen on this one have been the 0420/0430 which I expect to get (again) within the next week (French LPG) and the 030* mess I got t'other week.
« Reply #78 on: 17 April 2013, 08:21:59 »
Time you relocated the O2's then Nige!
The major issue we have on the diag here is the addition of the LPG system. As most will know, LPG piggy backs onto the Petrol ecu and modifies the injector pulses for use with LPG based on a few simple sensor inputs.
A downside of this is that there is the need to manualy map the system plus its a compromised approach hence its easy to see an LPG setup showing fuel trims which are not ideal.
It would be very good of the LPG setups would also monitor the O2' sensors and provide trims for the system.
« Reply #79 on: 17 April 2013, 10:43:12 »
When are you free ?  :)  :) :)
On a more serious note ..  Thanks for the info ... as mine is a BRC Sequent 56 system there is no manual mapping facility available to me, I believe - from reading the stuff I downloaded some while back - that the BRC "self maps", but I'm not 100% certain. According to that paperwork the ECU does have lambda inputs. I do know it has not been remapped since installed - I watched the last couple of "services" (3 & 4 years ago) which comprised of a filter change, a "sniffer" around the pipework, and plugging in an analyzer to the OBDII slot and stating "no problems" .. for which I was charged silly money. I've done my own filter changes/sniffs/and OBDII checks ever since .. :)
The LPG installers in Swindon (not the ones I used for conversion) have recently taken on the BRC franchise, do you think its worth having them "remap" or "recalibrate" the system ?? It has been in  5 years and 53,000 miles without one ??
« Reply #80 on: 17 April 2013, 10:50:00 »
Relocation of O2 sensors is much easier for me to do now thanks to the aquisition of a plasma cutter.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #81 on: 17 April 2013, 12:18:50 »
ooooo shiney!  :P
« Reply #82 on: 17 April 2013, 18:30:11 »
Thats convenient...  ...you're only about 80 miles from me :P
« Reply #83 on: 17 April 2013, 19:12:43 »
Perhaps we ought to form a queue .. :)
    • 530D M Sport, 330i Coupe
« Reply #84 on: 17 April 2013, 20:05:09 »
I'm closer......  :y
 ;D
Mind you, I not got 0420 or 0430's yet!..... My last 3.2 was the first one reported on here to get them though!
« Reply #85 on: 17 April 2013, 21:01:36 »
I'm closer......  :y
 ;D
Ah, so you drive like Miss Daisy then? ;)
« Reply #86 on: 18 April 2013, 09:53:37 »
The worst part about re-locating them is removing the front pipes.
« Reply #87 on: 18 April 2013, 09:59:28 »
That's the worry ... could be a 20 minute job or a 2 hour job ... makes asking someone to do it for you either a favour or an imposition, and you don't know which until the point of no return !!
« Reply #88 on: 18 April 2013, 12:23:32 »
Worst case scenario is drilling out the centre pipe bolts but, as the cat is being removed and given a good pillar drill thats not a big issue.
So parts required are:
2 off Lambda bosses
2 off Lambda boss blanking plugs
2 off front pipe to manifold gaskets
4 off centre section to front pipe bolts.
2 off new front pipe to manifold nuts (often not needed hence only two just in case!)
Then I would say 1-2 hours typical (less or best case)
« Reply #89 on: 18 April 2013, 19:40:04 »
I'm closer......  :y
 ;D
Jekyll and Hyde syndrome i'm afraid, I'm either driving in kickdown or gently trundling along with the traffic flow!
Pages: 1 2 3 4 5 [6] 7   Go Up
