Author Topic: Lincolnshire airspace ...........  (Read 3073 times)
Re: Lincolnshire airspace ...........
« Reply #15 on: 14 April 2013, 15:01:19 »
   There is talk about putting Lanc NX611 "Just Jane" back where it should be in the air. It's already having/had  fresh Merlin's fitted/being fitted.   You can at the moment win a taxi ride by winning a raffle they have before each taxi run, I tried a couple of times, NO LUCK, can't afford price of seat :'( :'(   Take some ear plugs with you, engines are run up in pairs, no use trying to talk. I moved from infront of aircraft and stood by the wing tip, thought it would be safer if the brakes failed :y :y
Ah yes, that is I believe the plane two brothers are pushing through restoration in memory of their Bomber Command brother who was killed in 1944. :y :y
PS Yes, this is the web site on this bomber: http://www.lincsaviation.co.uk/history/history-of-the-lancaster.htm  :y :y
« Last Edit: 14 April 2013, 15:03:23 by Lizzie Zoom »
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
« Reply #16 on: 14 April 2013, 16:28:06 »
http://youtu.be/hveqhCi6x0Y    That's right, he was a rear gunner, I think. Look how close you can get, without sitting in it :y :y
« Last Edit: 14 April 2013, 16:31:23 by DaveA »
Regards
    Dave
« Reply #17 on: 14 April 2013, 17:22:37 »
A "tail end Charlie" which those poor sods were sitting back their, with a death rate far higher than any other position in the aircraft. It was a very vulnerable position as the Luftwaffe would often approach and fire on the the bomber from the rear.
I once knew a chap who had served in Bomber Command during 1943-45 in that role, and he said he was one of the relative few to survive. So many of his comrades did not, and became one of the overall 55,573 to perish. :'( :'( :'(  Never forget them :y :y :y
