Author Topic: Starter motor  (Read 5470 times)
omegafin
  • xxx
Re: Starter motor
« Reply #15 on: 16 April 2013, 21:40:34 »
check earth strap between engine and body  it may be cut or loose ....
« Last Edit: 16 April 2013, 21:44:39 by omegafin »
Re: Starter motor
« Reply #16 on: 16 April 2013, 22:03:16 »
Ops been advised to do that before ;)  +1 :y
Re: Starter motor
« Reply #17 on: 16 April 2013, 22:05:20 »
Given the info about direct wiring to the solenoid, is it possibly simply the ignition switch ??
No contact when moving the key to the "start" position = broken wire/contact in the switch ??
or would that be way too simple a thought ??  ( 'cos I is simple ...  :)  )
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: Starter motor
« Reply #18 on: 16 April 2013, 22:25:01 »
Securely clamp a jump lead from the battery negative post to, say, a manifold stud on the engine.
78bex
    • 2.2 CD AUTO / FAZER 600
Re: Starter motor
« Reply #19 on: 17 April 2013, 01:56:46 »
So the mech has confirmed there is voltage going to the  terminal on the starter motor when the ignition switch is turned to the starter position.  can`t be anything else except a duff starter motor or the engine is seized solid. with everything switched off get a socket on the crank pulley & try to rotate the crankshaft. if it freely turns then all that is left is the starter motor. :y
omegafin
  • xxx
Re: Starter motor
« Reply #20 on: 17 April 2013, 06:25:16 »
Do this before you do anything else !
Just do it ...
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: Starter motor
« Reply #21 on: 17 April 2013, 09:04:55 »
How do i check starter relay as i have not a clue?
Post 95-96 Omegas do not have a starter relay. Direct feed from ignition switch to starter solenoid if manual, if auto, feed is linked through inhibitor switch under gearlever gaiter.
OP, have you checked the round connectors by battery are all secure and locked in position
Mine, which is emitted in '95 has starter relay that was really surprising when exploring it at starter swap. One of my firends has a miggy like mine, which does not have relay though. ??? So every Omega full of surprise!  :)
« Last Edit: 17 April 2013, 09:07:55 by Johnny English »
C20NE - X25XE
Re: Starter motor
« Reply #22 on: 17 April 2013, 15:41:49 »
95 was the cutover from the earlier relay based immobiliser to the full electronic system and hence why early cars have the relay (and the IR receiver)
ronomega
  • corby
    • mv6 03
Re: Starter motor
« Reply #23 on: 18 April 2013, 17:52:01 »
Thanx for help, i put it in garage today. I will let you know guy's.
ronomega
  • corby
    • mv6 03
Re: Starter motor
« Reply #24 on: 19 April 2013, 15:07:54 »
It was starter guy's.
Johnny English
  • Hungary
Re: Starter motor
« Reply #25 on: 19 April 2013, 21:28:45 »
Done!  :y
C20NE - X25XE
