Author Topic: glow plug relay  (Read 3077 times)
Re: glow plug relay
« Reply #15 on: 18 April 2013, 13:26:05 »
The ether fractured the rings, these then made a bid for freedom up the side of the piston taking some piston with it.
With the aid of the cylinder head, the rings fragments were then stamped into the crown and hence the damage.
We actauly found pieces of ring embedded into the piston
Thanks Mark  :y
Ooooo!  :o Doesn't sound good!   :(  :(
ahodgie
  • sunderland
    • omega 2.5 td estate auto
Re: glow plug relay
« Reply #16 on: 18 April 2013, 13:57:29 »
I find mine doesn't like to start if its been parked on a bank for any length of time facing up the bank so fuel can run back to the tank parked the other way it starts first time
Re: glow plug relay
« Reply #17 on: 18 April 2013, 14:25:56 »
The major problem is that its very volatile and ignites early in the compression stroke and hence clatters the rings.
If it was diesel, this is injected into the combustion bowl 20-30 degress before TDC and hence is a more controled combustion.
andyboy
  • airdrie scotland
    • 0mega 2.5 gls td
Re: glow plug relay
« Reply #18 on: 18 April 2013, 15:32:34 »
were are the leak off pipes located then  :-X cmon lads lol
Re: glow plug relay
« Reply #19 on: 18 April 2013, 15:35:29 »
From the injector pump to the injectors and between the injectors. If it's original it will have a material covering
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: glow plug relay
« Reply #20 on: 19 April 2013, 10:53:27 »
if the batterys well up it will eventualy start after about 5 0r 6 minutes..bought a multimeter to check plugs ,,but not sure how to use them lol im a plasterer so not to good with the technical side of cars  :-X help     :-\
Two checks you can do, the Relay can arc and or pit across the contacts meaning you can get intermittent current flowing to the GP's during warm up period, or the contacts intermittently make contact causing the GP's to be on when not required and cook the GPs, eventually killing them.
1, Voltage Check, one side of the relay is connected directly to the Battery so +12V should appear on the 6 wires feeding the GPs from the top of the relay during warm up mode, this voltage will stay there for approx 4 seconds after the GP Dash Light goes out.
2, Resistance Check, pull the connecter off the top of the relay and measure each GP in turn with earth or neg battery, each GP should measure approx 2 Ohms, if any are open circuit then its either a wiring issue or faulty GP.
On the 2.5 TDs it can only take 2 or more GPs to go and this will cause starting issues when cold.
Chris.   ;)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: glow plug relay
« Reply #21 on: 19 April 2013, 11:08:01 »
How much fuel's in the tank? :-\
