Author Topic: Sun visors and interior mirror Face lift  (Read 1672 times)
nilocp
  • Halifax, West Yorkshire
« on: 17 April 2013, 21:47:32 »
How do you get the sunvisors off and the interior mirror on a facelift. I cannot figure out where the wires unplug for the visors.
Colin
Re: Sun visors and interior mirror Face lift
« Reply #1 on: 17 April 2013, 22:51:21 »
Colin
The plug & socket are inside the headlining ..... remove the two screws holding the visor to the roof & all will be obvious.  :y
nilocp
« Reply #2 on: 17 April 2013, 23:01:51 »
Not obvious! Removed screws. The wire is very tight and will not pull out!
flyer 0712
« Reply #3 on: 17 April 2013, 23:07:02 »
Had the same problem....removed sun visor wires would not stretch..so removed interior light and then you can feel the wires...then i just pulled down gently on the front of the head lining and this allowed  the wires more room to be pulled out with the sun visor and then the plug is visible and you can unplug the visor   :y :y
« Reply #4 on: 17 April 2013, 23:34:47 »
The plug will be within 2" of the hole. Probably taped up by those lovely people at the factory ::)
pauls
  • By the sea minehead
    • Bmw x3
« Reply #5 on: 17 April 2013, 23:39:52 »
Once you have found the wires dont pull to hard. i did and the plug came off in bits. :'(
nilocp
« Reply #6 on: 18 April 2013, 18:48:32 »
Thanks guys, I pulled the head lining down and got interior light out, found the loom and pushed and pulled it through.
What a tw*t ::) ::)
Colin
