Author Topic: Towbar  (Read 1725 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Towbar
« on: 20 April 2013, 18:43:16 »
How easy is is it to fit one on my 2.2? are there any connectors hidden or is it breaking into wiring
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Towbar
« Reply #1 on: 20 April 2013, 18:57:58 »
Done one om my 2.2 last year ..was dead easy..i wired it in by cutting etc..there is a plug in boot. but my towbar was off a earlier omega.
ie: round and square plugs.. and you have to remove the padding/foam in the boot where plate is going. :y
http://www.omegaowners.com/forum/index.php?topic=102863.0
http://www.western-towing.co.uk/acatalog/Trailer_12N_wiring_diagram.html
« Last Edit: 20 April 2013, 19:06:26 by bigtimecube »
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Towbar
« Reply #2 on: 20 April 2013, 19:22:28 »
Where is plug located in boot is it hidden?
Steve B
  • Leicestershire
Re: Towbar
« Reply #3 on: 20 April 2013, 19:42:28 »
you will see it when you get carpet and plastic trim out.. its part of the cars wiring.but has said mine was no use.to me so i wired into loom.
Have a read here too   :y
http://oldsite.omegaowners.com/forum/YaBB.pl?num=1253120637/all
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
Re: Towbar
« Reply #4 on: 20 April 2013, 21:11:25 »
I'm removing the towbar and all the electrics off my facelift as I dont intend to tow anything and don't particularly like the look of it... If you live d nearer you could have it..
Steve B
  • Leicestershire
Re: Towbar
« Reply #5 on: 20 April 2013, 23:33:00 »
AFAIK. There are two types of this towbar (in the boot) PFL/FL (someone will correct me if i am wrong)
If you fit a FL tow bar to a FL its plug&play. Apart from jumping into the brake light circuit TO get the
brakelights working, or... fitting a relay under the dash
I fitted a PFL tow bar to my FL,so it was not plug&play (the square did not fit in the circle on the
electrics)so i had to cut&splice the electrics,I also had to chop the bumper, And the ball is very close to
the bumper with the earlier towbar,(PIC BELOW)But all i tow is a small tip trailer.
Talk to Andy b (He is into dealing with the far rear point of a omega)
He helped me with the electrical side.And my car ended up on fire   ;D ;D ;D ;D ;D
Re: Towbar
« Reply #6 on: 22 April 2013, 19:35:19 »
https://dl.dropboxusercontent.com/u/70807181/fitted.JPG
That was the other Andy B  ::) ::) ;D ;D ;D ;D  :y
Page created in 0.024 seconds with 20 queries.
