Author Topic: 4.22 Differential - 2.6 / 3.2 Omega's  (Read 5996 times)
SMD
  • London
    • :( nowt
Re: 4.22 Differential - 2.6 / 3.2 Omega's
« Reply #15 on: 23 April 2013, 09:44:55 »
Agreed. 3.45 with a petrol engine will be terrible - tractors only. ;D
Also, remember that those graphs show theoretical speeds in gears. If the engine doesn't have enough grunt to get there it won't happen.
4.22 in a 3.2 auto is probably a worthwhile mod, as the auto is quite high geared. (mine is far from bogging down at 130, mind.. apparently)  :-X
4.22 might be a bit much in a manual, as that is lower geared anyway, and the low gears in that gearbox are already pretty short, IMHO. IIRC, someone on here tried it (after a 2.6-3.2 conversion) and went for the 3.9 after trying it.
2.6 manual might benefit from a 4.22, but the auto already has it.
Thanks MV8  ;)
Kevin, I'm guessing by your post you have a 4.22 diff. Is the difference noticable?
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #16 on: 23 April 2013, 10:33:30 »
i have fitted a 2.5 diesel diff to my 3.2 manual and it drives fine and i was getting 28-29 mpg out of it and a higher top end
2001 MV6 3.2 manual been converted from 2.6 auto
SMD
  • London
    • :( nowt
« Reply #17 on: 23 April 2013, 10:49:09 »
Don't diesel diffs have different ratios than petrol and are tall geared for economy?
« Reply #18 on: 23 April 2013, 11:14:36 »
Thanks MV8  ;)
Nope. I haven't done it to mine. Purely a speculative comment. IIRC Chrisgixer did it and was happy with the difference it made. ;)
Then again, I once asked him what impact it had on fuel consumption and he gave me a funny look which told me he really didn't care much. ;D
« Reply #19 on: 23 April 2013, 17:43:02 »
My 2.5 diff has a leaky pinion seal.I have a spare 3.0 diff (both auto cars) which I could bung in there rather than change the pinion seal.Problem is,I dont know what ratio aeither a 2.5 or 3.0 are. :-\ ;D
Might be best to just change the seal I suppose. ::)
4:22 for the 2.5,   3:90 for the 3.0.
And before you ask ::) ;D
http://www.omegaowners.com/forum/index.php?topic=90497.0
« Reply #20 on: 23 April 2013, 17:46:00 »
Cheers Rob. :y
2.5 is already sluggish.Im thinking the 3.90 diff would make it even more so. ;)
« Last Edit: 23 April 2013, 17:47:47 by Albitz »
« Reply #21 on: 23 April 2013, 18:25:38 »
Cheers Rob. :y
Go on a diet then fatty ;D ;D
« Reply #22 on: 23 April 2013, 18:54:52 »
Its the bloody car that needs to diet.Its half a ton overweight for the power output. ;D
« Reply #23 on: 23 April 2013, 19:09:33 »
Chuck that heavy LPG tank out then :D
« Reply #24 on: 23 April 2013, 19:14:49 »
But then I would need to fill the petrol tank which holds a lot more liquid than the LPG tank. ::) :P
« Reply #25 on: 23 April 2013, 19:30:43 »
agreed ;D :y
