Pages: 1 [2] 3  All   Go Down
Author Topic: Fault codes  (Read 5271 times)
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Fault codes
« Reply #15 on: 11 May 2008, 18:18:13 »
Reading MarkDTM's excellent guide to fault codes, code 56 is Idle air control Voltage high.
http://www.omegaowners.com/forum/YaBB.pl?num=1207565474
Thats what i make it out to be too..Know whats the remedy.. ;D ;D
I'd start with the wishbones and see if that clears it.  ;)
I am already looking for a replacement..Once a car breaks down on me once its time for it to go..
Is the world ready for me..
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Fault codes
« Reply #16 on: 11 May 2008, 18:25:29 »
Start by checking cabling to the IACV, make sure its plugged in properly too otherwise could be its knackered.
TuBy's new whipping boy.
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Fault codes
« Reply #17 on: 11 May 2008, 19:31:37 »
I have been told it could be a relay, trouble is which one..Anyone identify relay M33 i think it was,,Does this make sense to anyone.
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Fault codes
« Reply #18 on: 11 May 2008, 19:56:42 »
Does anyone know where the relay is for the ICV.?
Re: Fault codes
« Reply #19 on: 11 May 2008, 21:07:45 »
There is no relay for the ICV, its directly controlled by the ECU!
And M33 is the idle valve!
There is a main supply relay which is K42 but, this also switches the supply to the injectros and a whole host of ther stuff.
As a little test, if it i the idle valve, then applying a small amount of throttle will work around it....
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Fault codes
« Reply #20 on: 11 May 2008, 21:13:21 »
I have plenty of throttle and revs but, When i rev it the fuel and temp gauges go to zero..
On tickover all is fine but give it throttle aand the ABS light comes on and needles drop to zero, also automatic gearbox is showing on display.
It was running ok when i parked it up last night.
Re: Fault codes
« Reply #21 on: 11 May 2008, 21:16:36 »
I'd check what happens to the battery voltage when you rev it. Sounds like something is happening to the supply for instrument panel, ABS and Autobox to get the hump at the same time.
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Fault codes
« Reply #22 on: 11 May 2008, 21:18:15 »
Thats why i thought it might be the alternator. :y
Re: Fault codes
« Reply #23 on: 11 May 2008, 21:19:02 »
I agree with Kev - as per my initial post.
Sorry my DSL died earlier mate.. we can still have a chat about it if you need a hand! :)
Re: Fault codes
« Reply #24 on: 11 May 2008, 21:19:33 »
Or the regulator..
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Fault codes
« Reply #25 on: 13 May 2008, 23:43:30 »
Have you managed to sort out your problem Spongebob?
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Fault codes
« Reply #26 on: 13 May 2008, 23:47:37 »
Had a problem with a Rangey Alternator a few years ago, something was allowing the current to go back up to the instrument panel.... but cant remember exactly what the problem was, regulator or diode..
Got a new alternator and it cured the problem
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Fault codes
« Reply #27 on: 14 May 2008, 00:40:51 »
Searching for an alternator as we speak.. :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Fault codes
« Reply #28 on: 14 May 2008, 01:05:53 »
Let us know how you get on mate....
On the Old Rangey we had when we turned the car off and took out the key the battery light used to come on :-?
But the new alternator did cure it something to do with current going up the D+ wire when it shouldn't :y
Baron Von Spongebob
  • South Wales
  • Living the dream
Re: Fault codes
« Reply #29 on: 14 May 2008, 17:20:29 »
Just an update for those thats interested,,,Car is fixed.
As i suspected a faulty alternator..
Thanks for your input everyone.. :y
Pages: 1 [2] 3  All   Go Up
