Author Topic: Wonky central locking  (Read 3245 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 24 April 2013, 20:23:35 »
Now the battery problem is sorted it appears the central locking is a bit upset, front doors work intermittently and at random when using the remote, is it possible they are out of sync somewhat?
Re: Wonky central locking
« Reply #1 on: 24 April 2013, 20:30:08 »
Usually when out of sync, they don't work at all.  However worth trying resyncing - its free :y
« Reply #2 on: 25 April 2013, 13:21:54 »
If they are even trying to work on the remote control then it's not a syncing issue.
Most common issue with central locking is microswitches in the motor failing.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #3 on: 25 April 2013, 14:57:18 »
Not wanting to steal the thread.
My drivers door one seems to have called it a day lately, I press the fob and the door buttons(except drivers) go up then down.
So i therefore have to use the key in the door,which then opens the car.
But all indicators are flashing until key is turned in ignition.
Is this normal when the central locking  microswitch motor fails  :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 25 April 2013, 15:40:40 »
Yup, sounds like your alarm horn is knackered too.
TuBy's new whipping boy.
Steve B
  • Leicestershire
« Reply #5 on: 25 April 2013, 17:57:34 »
So putting aside that it sounds like my alarm horn is not working,why has the alarm been triggered in the first place.Ive only opened the door mechanically.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #6 on: 25 April 2013, 19:32:46 »
That's normal operation, using the key doesn't disable the alarm.
Steve B
  • Leicestershire
« Reply #7 on: 25 April 2013, 20:38:29 »
Why on earth did vx do that  :-\ :-\ :-\ :-\ So everyone on here who decides to open there omega mechanically with the key,gets the alarm.IE; Flat fob batt
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #8 on: 25 April 2013, 21:05:44 »
God knows but every Omega I've had has done the same.
« Reply #9 on: 25 April 2013, 21:17:12 »
It's so you can't disable the alarm by picking the lock. Needs either immobiliser or keyfob remote signature to be recognised. :y
Page created in 0.023 seconds with 20 queries.
