Author Topic: Rear Track Arms  (Read 2235 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
Rear Track Arms
« on: 13 May 2008, 08:48:55 »
Reading Big Al's topic in General Chat about his visit to WIM, he was advised by Tony to spray the rear track arms with WD40 or similar.
I'm due to visit WIM on 21 May and I thought I better get busy with the WD40, but I have to admit I'm not sure where to spray it.
Does anyone have a photo of where to spray, or could they better describe what I'm looking for, and would it be easier to do with the wheel off?
Mr Hagon
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
psnimv6
  • tyrone n ireland
Re: Rear Track Arms
« Reply #1 on: 13 May 2008, 08:56:54 »
it is the bar that runs from the bottom of the rear shocks to the diff area with two nuts nearer the shocks this is where you need to spray the wd40 as this is where it will be adjusted but to be honest the best way to free them is to remove them from the car and put them in the vice as they will be very tight ( by the way it is the middle 2 nuts not the main shock bolts ) ;D
ians
  • Reading
Re: Rear Track Arms
« Reply #2 on: 13 May 2008, 12:34:58 »
It will be the rear tie rod which has the adjuster on it (similar to the ones at the front).
And I suggest using Plusgas - its intended for this, whereas WD40 is not (its a water dispersant, rather than a penetrating agent or a lubricant).  Yes I was sceptical too until I tried it - magic stuff.
Big_Roger
  • Southampton
Re: Rear Track Arms
« Reply #3 on: 13 May 2008, 15:32:30 »
Hi,
I had been spraying Plus Gas on mine prior to visit to Fleet fit, but it still needed Rustoff Freeze crack release agent before they would move.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Big_Al
Re: Rear Track Arms
« Reply #4 on: 13 May 2008, 15:48:20 »
I have some pictures of when I was at WIM -  actually showing the part concerned -but I am sadly very limited at operating the computer and would not have a clue of how to load them onto this site  :-[ :-[ :-[
Could e -mail them to you though - if you PM your e mail address
Regards, Big Al :y :y
Mr Hagon
  • South West London
Re: Rear Track Arms
« Reply #5 on: 14 May 2008, 10:14:46 »
Cheers Big Al, PM sent.
Mr Hagon
Big_Al
Re: Rear Track Arms
« Reply #6 on: 14 May 2008, 19:59:39 »
Mark, Have e- mailed pictures from WIM.
Also check you PM's
Mr Hagon
  • South West London
Re: Rear Track Arms
« Reply #7 on: 14 May 2008, 20:09:22 »
Big Al,
Pictures received in all their glory.  Thanks a million.  Will get outside now before it gets too dark and start off with the WD40.
The hunt for Plusgas continues.  My local branch of Camberley Auto Factors doesn't stock it but they're recommended a building trade supply store locally that I will try tomorrow.
Mark
P.S. no PM showing up.
Big_Al
Re: Rear Track Arms
« Reply #8 on: 14 May 2008, 20:18:40 »
Told you I'm a real s-l-o-w-y on the computer. Just sent it a minute ago. :-[ :-[ :-[
Regards Al :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Rear Track Arms
« Reply #9 on: 14 May 2008, 20:30:02 »
Big Al,
Mark
Sure I've bought from halfords in the past but last time I wanted some they didn't seem to have any. Engineers merchants stock it though, maybe worth looking up your local engineers merchants.
TuBy's new whipping boy.
Mr Hagon
  • South West London
Re: Rear Track Arms
« Reply #10 on: 14 May 2008, 20:30:34 »
Right, back half of the car done, now to the front as well.
Thanks for all the tips Big Al.
Mark
Big_Al
Re: Rear Track Arms
« Reply #11 on: 14 May 2008, 22:54:28 »
Another PM sent
Mr Hagon
  • South West London
Re: Rear Track Arms
« Reply #12 on: 15 May 2008, 13:30:07 »
Big Al,
Mark
The local building trade supply store had some Plusgas so I'm now the proud owner of a 200ml aerosol can.  Just a shame I will invariably get wet later when I get spraying.
Mark
Leomas
  • Boyne Valley (on loan)
  • Ooops what did I break this time?
Re: Rear Track Arms
« Reply #13 on: 15 May 2008, 13:39:52 »
Recommendation I had from a friend 'in the trade' was motorcycle spray chain lube. Had the penetration of WD40 but was a high spec grease with anti-fling to keep it in place. Never without a can now.
Recently 'learned up' and being more careful now, honestly.
Ummm except for where I fix one thing and break something else
