Author Topic: Genuine or Pattern gaskets?  (Read 3170 times)
« on: 14 May 2008, 20:45:52 »
Ok I risk setting the cat amonst the pigeons here, but I'm after a bit of a sensible/factual debate based on current curcumstances.
Circumstances are as follows. I have a poorly 2.0 16v Omega which I'm currently doing a top end stripdown, clean, and rebuild on a low budget.
Chances are when it runs I will sell the Disco, and I will need the 2.0 Estate to "get us by" for about 6 months.
My question (and I want to ask a wide audience) is this -
I have bought a head gasket set with every top end gasket/seal required to complete the build.
All mating surfaces are squeaky clean and smooth and new studs will be used.
Do I use the composite gaskets that came in the kit for the exhaust manifold, and also use the supplied camcover gasket -
Or should I splash out around £40 extra for the genuine VX ones?
If this was a newer, nicer car I wouldn't even be asking the question, but remembering the car's value (about £400 most when running) and the length of time I need it, I am tossing up whether properly fitted pattern gaskets in these applications might get me by.
Answers on a postcard ;)
I'm not convinced either way at the moment.
Re: Genuine or Pattern gaskets?
« Reply #1 on: 14 May 2008, 20:49:50 »
If it was a car I was going to keep I'd use the 'proper' GM gaskets. But in this case I think I'd use the pattern gaskets that came in the kit. Chances are it'll be someone else's problem by the time they fail.  ::)  :y
« Reply #2 on: 14 May 2008, 20:53:57 »
I suppose it depends on how long you intend to keep the car.
« Reply #3 on: 14 May 2008, 20:55:38 »
6 months max :y
« Reply #4 on: 14 May 2008, 20:57:17 »
6 months max :y
Use the gaskets u have - not worth extra expense - yours should easily last 6 months!
« Reply #5 on: 14 May 2008, 21:08:36 »
Well, the pattern cam cover gaskets are unlikely to last 6 months from bitter experience and the composite exhaust manifold gaskets are just not worth fitting.
Re-use the old cam seals though!
« Reply #6 on: 14 May 2008, 21:14:08 »
Are pattern cam cover gaskets on the 2.0 any better than the V6 ones?
« Last Edit: 14 May 2008, 21:14:22 by JamesV6CDX »
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
« Reply #7 on: 14 May 2008, 21:19:28 »
James, your back...............now i know i have been away too long!!! Welcome home  :y
smoothomega
  • 2002 2.2DTI CDX,
« Reply #8 on: 14 May 2008, 21:21:58 »
BTW James, if it were me i would stick the pattern parts on and keep my fingers crossed if this is not a long term car. £40 in the piggy bank towards the next one then  ;)
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« Reply #9 on: 14 May 2008, 21:42:14 »
Use the pattern ones..
I rebuilt my head 3 years ago using a gasket set from partco/unipart inc cam cover and manifold gaskets and i have no leaks at all.  I guess the 2.0lts arn't as prone to blowing the gaskets as the v6 ones.
lee
« Last Edit: 14 May 2008, 21:45:34 by lee4206 »
Baron Von Spongebob
  • South Wales
  • Living the dream
« Reply #10 on: 14 May 2008, 21:44:21 »
Get a pattern one..I like the ones with bunny rabbits on.. :D
Is the world ready for me..
« Reply #11 on: 14 May 2008, 21:44:49 »
Nope, equally as shite!!
« Last Edit: 14 May 2008, 21:45:28 by Mark »
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #12 on: 14 May 2008, 21:46:20 »
Thought you were into ferrets nowadays.
TuBy's new whipping boy.
Baron Von Spongebob
  • South Wales
  • Living the dream
« Reply #13 on: 14 May 2008, 21:47:22 »
 ;D ;D ;D ;D
« Reply #14 on: 14 May 2008, 21:48:15 »
lee
They are more prone!
Page created in 0.025 seconds with 20 queries.
