Author Topic: V6 Injector Removal  (Read 3321 times)
Re: V6 Injector Removal
« Reply #15 on: 05 May 2013, 20:02:46 »
Right, so re-assembled. All still same, as expected.
So moved 1 & 4 on DIS pack, again still same.
So disconnected 1 on the DIS, leaving 4 firing pot 1. Nothing going to real pot 4, again the same!
Which is good news, as that proves pot1 can bang away happily, for me this proves the DIS is at fault, so need to replace that.
« Reply #16 on: 05 May 2013, 20:44:02 »
Injector is operating and passing fuel ok, loom is fine (fault code would be raised if injector had an issue).
Sent on his way with a new flexi fitted to the 2.2 front pipe and some tests to do
Points to an ignition issue then :-\
Page created in 0.4 seconds with 16 queries.
