Author Topic: air valves  (Read 1773 times)
symes
  • oxford
    • R reg 940 volvo
air valves
« on: 01 May 2013, 18:52:43 »
the problem I have is when you press air recirculation button the fiap does not move-so replaced both and it worked for a few days now stopped again-what is going on- have just about had enough of it now and seriously am fed up with it!! so any ideas-  :'(
grain.ben
Re: air valves
« Reply #1 on: 01 May 2013, 21:01:08 »
Have you tried resetting the climate?
IIRC Keep buttons AUTO and OFF pressed simultaneously for about 10 seconds IIRC  :-\ Im pretty sure this resets all the flaps  :-\
symes
  • oxford
    • R reg 940 volvo
Re: air valves
« Reply #2 on: 01 May 2013, 21:15:35 »
tried that and no change - :'(  cheers anyway mate-
Re: air valves
« Reply #3 on: 02 May 2013, 11:34:09 »
A couple of things to try:
Do you get an electrical supply to the solenoid switched by the recirc button?
Is there a vacuum supply to the solenoid?
Does the vacuum get presented to the flap actuator when the solenoid is powered?
Does the flap actuator move when you suck on its' vacuum line?
symes
  • oxford
    • R reg 940 volvo
Re: air valves
« Reply #4 on: 02 May 2013, 12:27:49 »
read your reply mate-found it-cheers Kevin-wire in connector plug was fubar mate-just done it :y
