Author Topic: oil strainer bolts, how tight should they be?  (Read 3414 times)
Murph
  • Dartford, Kent
    • 2.5 Estate
Re: oil strainer bolts, how tight should they be?
« Reply #15 on: 06 May 2013, 20:40:22 »
I found it an easy job, but then I had the engine out and on a stand.
Remember to get some new sealant for the upper and lower joins when you reassemble. The grey goop from Vauxhall is generally recommended, but I used Loctite super high temperature silicone sealant and 300ish miles on I have had no problems.
