Author Topic: MV6 Exhaust Manifold Leak  (Read 8714 times)
cwill144
  • Oxford
    • 1998 MV6
« on: 05 May 2013, 10:14:01 »
The RH Exhaust manifold is blowing on my 3.0L MV6, can't see if it is cracked or the gasket. at first I thought it was the Manifold to exhaust joint but that is ok. Can't anyone tell me how hard a job it is to remove the manifold to replace the gasket, I have read the studs can snap and there is the access issue. any tips would be appreciated.
RobseyMV6
  • west sussex
Re: MV6 Exhaust Manifold Leak
« Reply #1 on: 05 May 2013, 10:27:48 »
Know you say right hand side but say your in side the car, what side then.
It's not a great job, i did one only last weekend for mot as was ticking bad on start up and clearing a little when hot.
Job took me over four hours as coolant pipe had to be removed also :(
Mine was drivers side so that the easy one in my eyes.
cwill144
  • Oxford
    • 1998 MV6
« Reply #2 on: 05 May 2013, 14:31:00 »
Did the nuts come off the stud ok? and how is the access? when you say ticking did you change the manifold and gasket then?
RobseyMV6
  • west sussex
« Reply #3 on: 05 May 2013, 17:12:38 »
Only manifold gasket, you can't remove the manifold without  A LOT of work!!!
All studs come out, in my eye's that was easy that way!
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #4 on: 05 May 2013, 21:37:47 »
Oh man! I'm looking at doing mine over the next few days!!!
Changing over to 3.2 manifolds.... I've been looking at it for days and knowing my luck, I will snap a stud or 6!!!!
Good luck cwill144....
Oh, and I broke all four bolts in the cat's!!! Ffs!
cwill144
  • Oxford
    • 1998 MV6
« Reply #5 on: 14 May 2013, 16:41:34 »
Still haven't done the job yet but what is the advantage of changing to 3.2L manifolds? do they fit the Exhaust pipes?
and will the drivers side manifold come off to change the gasket?
HockeyDave55
  • Milton Keynes
« Reply #6 on: 14 May 2013, 19:41:15 »
I just did my off side and it was a pig of a job, on and off I probably took about 6 or 7 hours to do it (trying to dodge life and the weather) and I've still not finished or even started the near side...
Mine was blowing because it didn't have a gasket and half the studs were loose...
As for the advantages, the 3.2's are supposed to be freer flowing and they don't use the SAI so mine's fitted to the bin....
symes
  • oxford
    • R reg 940 volvo
« Reply #7 on: 14 May 2013, 19:50:33 »
vibration can loosen the nuts-well that's what I reckon anyway- pig of a job to do manifolds while in car however not impossible-problem is coolant pipe/heat shield removal-after that-easy :y However left side is total pig of a job TBH- :y
HockeyDave55
  • Milton Keynes
« Reply #8 on: 14 May 2013, 20:07:27 »
TOTAL PIG!!! Lol...
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #9 on: 14 May 2013, 20:54:26 »
out of interest how do you guys locate manifold leaks? I still have some blowing on start up  :'( but then goes so presumably its small and the heat expands the metal to close it up.
but obviously theres a dirty great heat shield and other stuff in the way
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
« Reply #10 on: 14 May 2013, 22:52:40 »
it's not blowing out of the pipe to egr is it? they split
« Reply #11 on: 15 May 2013, 06:58:58 »
It will blow all the time not just on start up if its the rubber pipes :y
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 15 May 2013, 07:49:44 »
I meant the copper pipe that goes to egr  ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #13 on: 15 May 2013, 08:18:45 »
Oh, and I broke all four bolls in the cat's!!! Ffs! :-*
Dave if its just the exhaust to downpipe bolts that youve snapped, just drill them out with a 5/16 drill and use nut n bolts, if its manifold to downpipe then drill out rethread with m10 tap and use new studs,or m10 stainless bolts.
Hoof'land storeman.
symes
  • oxford
    • R reg 940 volvo
« Reply #14 on: 15 May 2013, 08:29:18 »
+1 :y-always seem to snap bolt's on cat's to silencer IMHO
