Pages: 1 2 3 4 5 6 7 [8] 9 10   Go Down
Author Topic: Parking sensors not working...  (Read 49637 times)
    • 530D M Sport, 330i Coupe
Re: Parking sensors not working...
« Reply #105 on: 21 May 2013, 20:57:16 »
Ah this is an X SVO vehicle by the look of that LED lamp. One of the DPG fleet?
Incidently, I may have mentioned this before..... As others may have.
"Don't bother looking for the park sensor speaker, just use another speaker and modify the loom"
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #106 on: 21 May 2013, 21:10:50 »
Elite Pete ownd it around late 2007.. Before that an chauffeur car.
« Reply #107 on: 21 May 2013, 21:28:40 »
why not just unplug the speaker and test it from the connection you can see...  removing it if it works is a tad pointless ???
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #108 on: 21 May 2013, 21:48:10 »
Cant find it otherwise i would test it. Never mind for now not going to be removing the whole roof trim.
« Reply #109 on: 21 May 2013, 22:50:20 »
You`ve located the speaker wires, thought it would be a simple task to trace them.  :-\
« Reply #110 on: 21 May 2013, 23:06:15 »
your picture shows the brown wires and the plug/socket ... just unplug and test !!!
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #111 on: 21 May 2013, 23:09:19 »
That plug  ??? connect any speaker there to see if they work ?
« Reply #112 on: 21 May 2013, 23:36:32 »
either connect any speaker to the ecu side, or a 9v battery to the speaker side and listen for "clicks" as you make/break the connection .. crude but simple way of testing a speaker .. if you hear a noise the speaker works and the problem is elsewhere ....
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #113 on: 21 May 2013, 23:48:21 »
I think i finally understand your plan now at last  :-X sorry.
(green text should have said or connect speaker here...)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #114 on: 22 May 2013, 00:14:24 »
I'm interested in knowing what SVO / DPG stand for .. And I presume it's not a good thing that its one of these  :-\ ..was an ex chauffeurs car and being the elite most likely not ex plod ?
« Reply #115 on: 22 May 2013, 00:41:46 »
Assume nothing...
Joffs old 3.2 Elite estate, (now in Scotland), was ex Met.
SVO=Special Vehicle Order, any none retail order, possibly MoD, exact spec could depend on original purpose.
DPG=Diplomatic Protection Group, a division of the Met, cars usually red, and usually show V6 Special on the log book.
Does the speedo have a calibration sticker on it?
The red connector blocks on the rear courtesy light are absolutely cack all to do with the park pilot.
Carefully pull that black cable that you found behind the c pillar trim, and you will find the speaker attached to the end of it. You'll need to REMOVE the trims in order to drop that side of the roof lining to be able to remove the speaker.
So as per the guide... grab handles off, passenger sunvisor off, pillar trims off, rear screen trim off. Pop the left hand side of the headlining from the body, and carefull pull it down. The speaker should then
A. Be clearly visible, and
B. Be easily removed.
« Reply #116 on: 22 May 2013, 00:44:52 »
Rob G, Reply #7, Page 1 ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #117 on: 22 May 2013, 00:54:13 »
Assume nothing...
Speedo is like any other Omega, Seen an ex plod more finer white lines.
I'll try Entwood's suggestion 1st if no luck might try a more involving job later down the line it's not like their a necessary that must be fixed straight away just annoying they don't work.
« Reply #118 on: 22 May 2013, 01:49:37 »
Biggest difference with calibrated speedo is the calibration certificate number just above the trip meter.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #119 on: 22 May 2013, 02:20:09 »
Ah it's definitely standard then so not ex police by looks of it. Maybe the Chauffeur company put that rear reading light in the rear then  :-\
Pages: 1 2 3 4 5 6 7 [8] 9 10   Go Up
