Author Topic: Pedal trick codes ?  (Read 1734 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Pedal trick codes ?
« on: 08 May 2013, 16:07:42 »
Would someone be kind enough to read them for me I've no idea how to check what the mean.. I made a video of the flashes uploaded to YouTube...
http://youtu.be/ubvqBJ5792s
Thanks
Re: Pedal trick codes ?
« Reply #1 on: 08 May 2013, 16:16:40 »
Four codes:
P0650
P0420
P0430
P0130
P0650 Malfunction Indicator (MI) Control Circuit High Instrument
P0650 Malfunction Indicator (MI) Control Circuit Low Instrument
P0650 Malfunction Indicator (MI) Control Circuit Open Instrument
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0130 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0130 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0130 O2 sensor circuit malfunction (Bank 1 Sensor 1)
P0650 - Do all your warning lights work? The answer from the video appears to be no, your emissions light isn't coming on, hence the P0650 I imagine. Someone probably removed the bulb to cover up the..
P0420/P0430 - the code that every 3.2 will get at some point. Needs the post-CAT O2 sensors moving behind the main CAT instead of between the preCAT and main CAT.
P0130 - Indicates a fault on an O2 sensor which probably needs live data to see if it's a slow O2 sensor or something else causing a fault on that bank.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #2 on: 08 May 2013, 16:23:15 »
Nothing too serious then  :o considering its almost done 190k
« Reply #3 on: 08 May 2013, 18:17:24 »
What he says above.
Long term masking of the codes may shag the cats, as that 0130 may result in overfuelling (or underfuelling, but the engine hasn't gone bang yet).
Fix it.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 08 May 2013, 18:59:35 »
If it passes mot without any serious or expensive problems i'll try and fix everything that's wrong with it... If not bye bye 3.2  ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5 on: 09 May 2013, 00:09:15 »
What he says above.
Fix it.
Is there a guide on how to do this and how much are these sensors on average, is it an easy job ?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6 on: 09 May 2013, 00:14:48 »
What he says above.
Fix it.
Strange that its running perfectly fine with these codes the engine, I'm sure my 2.2 has similar issues but no pedal trick to make one worried  ;D:-\
« Reply #7 on: 09 May 2013, 18:29:43 »
What he says above.
Fix it.
The Lamda needs diagnosis first. If its the sensor, about £90 for pattern.
Moving rear sensors, about £15 in parts, plus a friendly welder.
