Pages: 1 ... 3 4 5 6 7 8 9 [10] 11   Go Down
Author Topic: CID in "full" use  (Read 68672 times)
chrisgixer
Re: CID in "full" use
« Reply #135 on: 14 October 2014, 02:38:19 »
Doesn't this result in losing the Computer side of things :-\
This?
chrisgixer
« Reply #136 on: 14 October 2014, 02:47:03 »
You need a single din head unit to run the CID. 2011 is it?
Apologies. What I meant was, ncdc 1500. TB has one with CID in his mini face lift mv6. Telematics in the Bose shelf in the boot.
And Al. If this is what you mean, it's FULLY functional. :y looks smart too. :)
« Reply #137 on: 14 October 2014, 03:22:54 »
Ah ok, makes a bit more sense... was partly what I couldn't get my head around, hence the Fony suggestion :-[
That HU I suggested elsewhere, fitted with a MID would give everything you required except Bose ::)
But if the fully functional CID keeps the trip computer, connects to AV inputs such as mirror link, works with telematics, Bose and the original HU/control then it will be the mutts... 8)
chrisgixer
« Reply #138 on: 14 October 2014, 03:42:59 »
WTF WOULD I WANT TO LOOSE BOSE AL? ;D
That fony pile of  :-X will loose bc/check control/and the cid in the dash to replace it with a screen behind the gear stick. Why on earth would I want to do that?
Stop with the fony head units. It's not happening. ::)
« Reply #139 on: 14 October 2014, 09:08:37 »
WTF WOULD I WANT TO LOOSE BOSE AL? ;D I'm sure you said you wouldn't... ;D
That fony pile of  :-X will loose bc/check control/and the cid in the dash to replace it with a screen behind the gear stick. Why on earth would I want to do that? The cid would be replaced with a mid, keeping the bc/check control ::)
Stop with the fony head units. It's not happening. ::) I know... re read the last sentence of my previous post ;D
Daft brush... :P
« Last Edit: 14 October 2014, 09:19:47 by Doesn't play well with others... »
« Reply #140 on: 14 October 2014, 09:56:40 »
With Mirror link, the HU repeats what is on your phone screen... be it maps/gaypod/phone, so assuming the phone is mounted in sight/reach it effectively becomes the mid display :y
Not that it matters, as you have and like your current set up :y
Might be of interest to others without Bose though...
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #141 on: 14 October 2014, 10:06:05 »
It is of interest, definitely!  :D
« Reply #142 on: 14 October 2014, 10:08:37 »
 ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #143 on: 14 October 2014, 10:09:35 »
How many would you like.  ;)
« Reply #144 on: 14 October 2014, 10:50:17 »
Thing is, for a long while I've wanted to uprate, one some level, the MFD. Utilise the space. Maybe... Fit a Tom-Tom in the space - but you'd lose the MFD. Install a later stereo, with FL screen. A computer screen with rasberry pi (again, Id lose the MFD) But I'm in no way computerey. So very much looking for options/suggestions  :)
PS - For a PFL '96 with SC804 and boot mounted autochanger...
chrisgixer
« Reply #145 on: 14 October 2014, 13:39:07 »
indeed it would. But who, with a CID, doesn't have bose? Very few. Wel me in fact in the project. ;D
I still wouldn't replace it with that Chaved up rubbish. Personally :P
chrisgixer
« Reply #146 on: 14 October 2014, 14:00:53 »
Daft brush... :P
So on a thread about a CID in full use, you want to remove the CID?
zirk
  • Epping Forest
« Reply #147 on: 14 October 2014, 14:31:42 »
Didn't think iCraple worked with MirrorLink (well not fully anyway). MirrorLink was a Nokia thing before they gave the idea away for open source developers ie, Nokia, Samsung, Android users, etc.
« Reply #148 on: 14 October 2014, 17:57:32 »
Daft brush... :P
I was simply questioning the benefits... I actually admire the slightly stubborn nobility of what you're trying to achieve :y
chrisgixer
« Reply #149 on: 14 October 2014, 18:19:01 »
There's nothing stubborn or noble about it. Just development. Same with any other part of the omega.
Pages: 1 ... 3 4 5 6 7 8 9 [10] 11   Go Up
