Author Topic: Indicator bulb's are good but not flashing  (Read 3168 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 13 May 2013, 17:14:01 »
Hi guys, as above, when I put the indicators on (right or left) they stay solid and don't flash.
obviously the bulbs are good as I've checked and all bulbs are on.
can someone post up a fusebox layout as i'm presuming I need to check the fuses for the indicators. I also assume there's a ''flasher'' system and I presume theres a relay/fuse for that too. if you can tell me where this is?
then if all that's good am I looking at a new flasher unit?
RIP Paul Lovejoy
Re: Indicator bulb's are good but not flashing
« Reply #1 on: 13 May 2013, 17:15:26 »
what happens when you put the hazzards on?
Webby the Bear
  • Northampton
« Reply #2 on: 13 May 2013, 17:19:26 »
excellent point. 2 ses.....
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #3 on: 13 May 2013, 17:21:18 »
yep, still the same.... on but no flashing.........
RIP Paul Lovejoy
« Reply #4 on: 13 May 2013, 17:24:53 »
Try turning hazard switch on and off about 20 times ;)
If that doesn't work I'd suspect flasher unit
Webby the Bear
  • Northampton
« Reply #5 on: 13 May 2013, 17:25:51 »
already done that mate  :'( :y
RIP Paul Lovejoy
« Reply #6 on: 13 May 2013, 17:33:08 »
Didn't you have the same problem a while back Webs?  What did you do then to fix?
« Reply #7 on: 13 May 2013, 17:33:19 »
The flasher relay is in the fuse/relay box under the steering column.  :y
« Reply #8 on: 13 May 2013, 17:34:08 »
Next to diag socket IIRC
Webby the Bear
  • Northampton
« Reply #9 on: 13 May 2013, 17:42:12 »
spot on guys.... which is the number to check.....
http://oldsite.omegaowners.com/forum/YaBB.pl?num=1161602010/0
dbug, youre spot on it did happen a while back. but sorted itself out when I was mashing the hazrds a few times. how strange!
if the fuse is good wheres the flasher unit located?
cheers guys
RIP Paul Lovejoy
« Reply #10 on: 13 May 2013, 17:44:41 »
cheers guys
The flasher relay is in the fuse/relay box under the steering column.  ......  ::) ::)
Webby the Bear
  • Northampton
« Reply #11 on: 13 May 2013, 17:47:43 »
cheers guys
I assumed there was a relay AND a flasher unit (like an actuator), soz  ::) :y
in the link I posted is it no. 2 fuse/relay?
RIP Paul Lovejoy
« Reply #12 on: 13 May 2013, 17:52:45 »
cheers guys
Not sure without going & looking   ;) (I'm comfy  ::)). I normally feel for the one that's clicking when the indicators/hazards are on  ::) ::)
Webby the Bear
  • Northampton
« Reply #13 on: 13 May 2013, 17:54:06 »
cheers guys
lol no worries ill go and see what I can do now cheers andy  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #14 on: 13 May 2013, 18:04:21 »
Thanks guys all sorted.
Checked the relay and it wasn't clicking  ::) :y
Swapped it out for the one taken off Ralf..... all sorted  :y :y :y :y :y
cheers dudes
xxx
RIP Paul Lovejoy
Page created in 1.061 seconds with 20 queries.
