Author Topic: EEEK!!  Thought I had Broke it  (Read 2677 times)
« on: 15 May 2008, 18:41:10 »
Well, I finally sat in the new Miggy Elite today after buying it on the 27th last month. (My birthday pressent to self)
As you can guess, battery was flat, no remote locking.  Could'nt get the door to unlock on the key, but got the boot open.
My mate squeezed through, poped the arm rest down and tried to pull a door lock up, no joy there.  He mangaed to get over and pull the bonnet.
Leads connected and off went the alarm, where's the keys   hehe.
Had to leave the GLS running for a while before we got some juice in the battery but at least we got it started.
Ran it for a few mins, adjusted the seats and jumped it and started checking it over.
Sussed out the sun roof, got some tunes going, put the air con on, (Instant chill)  checked the phone on the head unit and found out my new mobile number.  Checked all the lights etc you know, play. play, mmmm more gadgets had a dable with the sat nav.
Then went to double check everything else.  at this point the lights had all be on/off, tried hazzards, rear blind, whilst all of this had been happening the drivers door was wide open (no buzzer)
Tried the hazzards, all he climate buttons and then switched the heated drivers seat on.
OPPS
No aircon at all, no heated seats, but there was a buzzer sounding.  So turned off the engine and started it back up thinking everthing would reset itself.
Tried my best thinking I had to reset the climate, but just could not remember what I had read to do it.  Then I realised there were no dashes lit up on the temp settings.
Haynes manuel out, yup, had blown the fuse, panic over.
Every thing I have found/checked works perfectly on the car apart from the sat nav, and the problem there is me.
2 questions?
How do I rest the climate when given the errors it displays if it screws up.
and
Does the fuse blow on the heated seat due to an overload, or is it a safety feature.
It was fitted with a 30amp fuse and was correct according to the book.
TIA
Richie London
  • heathrow
Re: EEEK!!  Thought I had Broke it
« Reply #1 on: 15 May 2008, 18:45:14 »
i think you press off and auto together for 5 seconds
richie
« Reply #2 on: 15 May 2008, 18:47:42 »
I thought I was right, had tried it.
But I also seem to remeber the error is that the 2 temp displays show --  --
With this in mind it seemed to prove that it didnt need the reset.
« Reply #3 on: 16 May 2008, 08:40:37 »
there is a fault with it.
« Reply #4 on: 16 May 2008, 08:43:58 »
Or was a fault with it.....the dashes indicate that a code is stored and wont go until the fault codes are cleared with Tech2.
It could of course be a battery low error code.
« Reply #5 on: 16 May 2008, 08:45:59 »
I think low batt one on these don't cause the --
On MID display, is outside temp ok?
« Reply #6 on: 16 May 2008, 08:46:53 »
unrelated, but I've seen a number of failures on the dual solar sensors fitted to facelifts recently...
« Reply #7 on: 16 May 2008, 08:50:02 »
Just checked the codes and you could be right.
00010      Compartment Temperature Sensor Voltage Low
00011      Compartment Temperature Sensor Voltage High
00012      Left Air Outlet Sensor Voltage Low
00013      Left Air Outlet Sensor Voltage High
00014      Right Air Outlet Sensor Voltage Low
00015      Right Air Outlet Sensor Voltage High
00016      Interior Flap Motor Voltage Low
00017      Interior Flap Motor Voltage High
00018      Left Blending Flap Motor Voltage Low
00019      Left Blending Flap Motor Voltage High
00020      Right Blending Flap Motor Voltage Low
00021      Right Blending Flap Motor Voltage High
00022      Floor Flap Motor Voltage Low
00023      Floor Flap Motor Voltage High
00024      Defroster Flap Motor Voltage Low
00025      Defroster Flap Motor Voltage High
00026      Blower Motor Voltage Low
00027      Blower Motor Voltage High
00028      Air Circulation Valve Voltage Low
00029      Air Circulation Valve Voltage High
00030      Heating Cutoff Valve Voltage Low
00031      Heating Cutoff Valve Voltage High
00051      Replace Electronic Control Unit (ECU)
00052      Variant-Coding Not Programmed
00055      Replace Electronic Control Unit (ECU)
00169      Outside Temperature Sensor Voltage Low
00171      Outside Temperature Sensor Voltage High
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
« Reply #8 on: 16 May 2008, 09:34:03 »
Mmmmmmm....3.0 Elite...my favorite.
Growing old disgracefully...
« Reply #9 on: 16 May 2008, 13:17:40 »
But what is the fault. ?  as the climate was completely dead.
All is welll, replaced the fuse as I mentioned.
Never having been in an Elite before we were just trying everthing and we were still put juice in the battery being in tickover.  Air con on auto and then switching on the heated seat.  Just didnt know if it was a safety thing or an overload.
No fault showed on the aircon or mid (not that I was paying attention to that)  Ijust remembered there was no display on the temp, and the rear blind wasnt working any more, ciggi lighter etc not working.
« Last Edit: 16 May 2008, 13:18:51 by skruntie »
« Reply #10 on: 16 May 2008, 13:20:55 »
There were no -- -- dashes as the display was completely dead.
