Author Topic: Autobox kick down.  (Read 2128 times)
tidla
  • solihull
Autobox kick down.
« on: 14 May 2013, 18:36:46 »
Using the omega for a run around at the moment, city driving.
In the old days of auto, there used to be a physical switch under the throttle so when floored the box would drop a cog or two.
What s used on the omega?
Seems about as decisive as a woman in a shoe shop and as quick to change as me getting out of bed in the morning.
I_want_an_Omega
Re: Autobox kick down.
« Reply #1 on: 14 May 2013, 18:48:35 »
There is a switch on the throttle cable. It's just inside the engine bay & tucked away near the scuttle. It just tells the ECU that the pedal is all the way down which in turn will command the autobox ECU to change down if conditions are right.
If there is too much slack in the cable then it can appear not to do anything as all the travel is taking up the slack rather than stretching the cable & operating the switch.
Hope that makes sense ..........
« Reply #2 on: 14 May 2013, 22:26:08 »
and later cars are drive by wire throttle  :y :y
tidla
  • solihull
« Reply #3 on: 14 May 2013, 22:47:54 »
Kickdown on a dbw controlled by the throttle potentiometer?
« Reply #4 on: 14 May 2013, 22:49:37 »
I assume so  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 14 May 2013, 23:03:43 »
Kickdown on a dbw controlled by the throttle impotent-iometer?
fixed that for you ;D ;D ;D ;D
the alarming man
  • medway kent
    • disco V8
« Reply #6 on: 16 May 2013, 13:02:14 »
i am not sure about that  the as mine is DBW but you can feel the switch when you floor the acelerator :y
« Reply #7 on: 16 May 2013, 14:28:51 »
There's a detent in the throttle sensor that gives a noticeable "click" but there doesn't appear to be any wiring to a switch so it uses the throttle position sensor to detect when to kick down.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #8 on: 16 May 2013, 21:11:55 »
Just checked mine when the accelerator pedal is welded to the floor you can feel a switch on the 2.2 & 3.2  ;)
flyer 0712
« Reply #9 on: 16 May 2013, 21:19:08 »
Yep on mine i can feel it click too  :y
