Author Topic: ENGINE STOPS UNEXPECTEDLY!!!  (Read 4764 times)
VOYAGER
  • ANKARA/TURKEY
    • 1998 Omega CD V6 AUTO
« on: 23 May 2013, 15:16:57 »
Hello...
After the replacement of the cam gaskets and cleaning the butterfly valve (even if the mechanic did not advise this clean up...), engine has been behaving so strange especially at the traffic lights. >:(
In addition to the first start at the parking lot; while waiting for the green light, engine stops unexpectedly and does not start at the first cranking. After a few attempts, I usually succeed starting the engine but, unfortunately, since most of the Turkish drivers are not so patient, you can not imagine the honking horns... :-[
Besides, when idle, whenever I attempt to accelerate suddenly like kicking the accelerator pedal, engine stops instead of revving...If I depress slowly, engine behaves normally and stsrts revving...After a successful start, idle is normal like nothing has happened... ???
I guess, I will be the first one who can succeed to have the automatic car stop before the first move at the traffic lights...I may be included in the Guinness World Records soon... :D
So, what are the probable causes for this? :-\
Answers will be greatly appreciated. Thanks... :y
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: ENGINE STOPS UNEXPECTEDLY!!!
« Reply #1 on: 23 May 2013, 16:38:01 »
What car is it engine wise ?
« Reply #2 on: 23 May 2013, 17:50:59 »
If its a V6, I'd suspect crank sensor, dirty ICV or dodgy MAF.  Any codes?
When I drove in Turkey it seemed you had to drive with one hand on the horn all the while  ;D ;D ;D ;D ;)
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #3 on: 23 May 2013, 17:52:40 »
Often is the crank sensor if V6. Certainly was on mine. Mine completely failed and no start at all. The dash warning light displayed on mine when the fault happened IIRC?
« Reply #4 on: 23 May 2013, 21:02:34 »
Hello...
* change this mechanic without hesitation
* agreed above ,its crank sensor .. also before purchasing anything either try paper clip test or have a live tech 2 session.. you may have other small  problems also..
ps: be sure its the correct crank sensor model..
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 23 May 2013, 22:54:30 »
If v6-crank sensor or slack throttle cable :y :y
VOYAGER
  • ANKARA/TURKEY
« Reply #6 on: 24 May 2013, 06:34:54 »
Agreed... :yYou have to have extra abilities while driving here... :-[
Not a proud but, nothing can heal it for now... >:(
No code with the exception of LH side oxygen sensor which I did not want to replace on purpose....
« Reply #7 on: 24 May 2013, 09:01:28 »
Voyager, you can come here at the weekend and try with my MAF if you are suspicious .. but my money is on the crank sensor :y
symes
  • oxford
    • R reg 940 volvo
« Reply #8 on: 24 May 2013, 18:28:14 »
There you go= problem :y
VOYAGER
  • ANKARA/TURKEY
« Reply #9 on: 25 May 2013, 20:50:19 »
Ones who put their money on crank sensor.... :-X
They won!!!... :D
I had it replaced today and everything works perfect... :y
Thanks mates... :) :y
« Reply #10 on: 25 May 2013, 20:56:15 »
They won!!!... :D
No probs glad you're sorted mate :y
VOYAGER
  • ANKARA/TURKEY
« Reply #11 on: 25 May 2013, 21:20:33 »
They won!!!... :D
Thanks dBug... :y
I'm so happy to hit at one shot... ;D
« Reply #12 on: 26 May 2013, 20:23:29 »
They won!!!... :D
Glad to hear its sorted..  :y   you need to sort that lambda also :-\
VOYAGER
  • ANKARA/TURKEY
« Reply #13 on: 28 May 2013, 18:00:49 »
They won!!!... :D
Allright Cem, :y
I will give it a try as soon as I stop "bleeding"... :o ;)
