Had a quote from VX for some parts.
Started by Mr.OmegaMan, 23 May 2013, 21:45:14
They always drop into the belly pan for me...  :(
So crawl underneath, undo it, retrieve tool/bolt, do it up, carry on, drop tool/bolt, Oh FFS!!  ::)  ;D
My post count is a bit like that lately now that you mention it ::)
bored bigyin54
just found out got none of the sockets to take cam cover of >:( >:( >:(
Steve B
Quote from: bored bigyin54 on 20 June 2013, 15:23:54
What did you use last time  ::) ::)
omegod
Normal 8 mm socket should do it
bored bigyin54
the last time it was on a 2.0 used allen key to take them off. do it now when rain stops will try 8mm socket  :y :y
bored bigyin54
#142
Quote from: tunnie on 21 June 2013, 09:28:33
E10 is correct socket.
thanks tunnie :y :y all i got to do now is get started on it ;D ;D
Quote from: bored bigyin54 on 21 June 2013, 15:45:47
You read over the guide I made?
http://www.omegaowners.com/forum/index.php?topic=90597.0
Worth giving breathers and throttle body a full clean while there, when putting it back together, double check the half moons are seated right at the back of the head & sealed well to the cam cover.  :y
I'd also leave it for a while before running it up to full operating temp, start it, to check, but don't let it get to normal temp.
bored bigyin54
Quote from: tunnie on 21 June 2013, 16:31:09
yes i looked at it ,only thing that changed from the 2.0 is no plug leads :y :y
