Author Topic: Rear Brake Pads  (Read 14266 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Rear Brake Pads
« Reply #15 on: 25 May 2013, 21:52:22 »
brake discs rear non vented 90444513
brake pads 9192126
hand brake shoes 90541931
fitting kits from a lokal factor about £11.00  :)
Hoof'land storeman.
Re: Rear Brake Pads
« Reply #16 on: 25 May 2013, 22:00:51 »
brake pads 9192126
90541931  £79.00  £67.21  £47.95  :o :o
Buy a few pairs from a factor with that money
biggriffin
Re: Rear Brake Pads
« Reply #17 on: 25 May 2013, 22:22:06 »
brake pads 9192126
blimey rear shoes from factor about £20.
got a genuine set in the store,best keep them in a safe. ;D
Hoof'land storeman.
Re: Rear Brake Pads
« Reply #18 on: 25 May 2013, 23:24:57 »
I've just bought a complete rear brake set for £66 which includes discs, pads, shoes and the fitting kit!!  :)
It's probably made from cardboard though at that price, but hey ho funds are tight and if it gets the old girl through the MOT....  ;)
biggriffin
Re: Rear Brake Pads
« Reply #19 on: 26 May 2013, 17:32:28 »
Thats good,from a factor or tinternet.
Hoof'land storeman.
Re: Rear Brake Pads
« Reply #20 on: 26 May 2013, 22:22:19 »
Fleabay!  :y
brian36
  • Milton Keynes
  • 2.6 mv6
Re: Rear Brake Pads
« Reply #21 on: 27 May 2013, 16:06:33 »
hi worth calling couple dealers i went to arnold clark vauxhall a few days ago and luckily they had some old stock and last set of genuine gm rear pads,shims,fixing kit normally £59 got for £19.10 .so worth a couple calls i reckon
i use square ones part number for box i got 9193476  :y
biggriffin
Re: Rear Brake Pads
« Reply #22 on: 28 May 2013, 13:04:20 »
Looks like tc price to me,minus vat. I could be wrong.
Hoof'land storeman.
slowboy
  • lode
Re: Rear Brake Pads
« Reply #23 on: 28 May 2013, 14:35:04 »
There are two types of fitting kits short & long both pins and springs
9jdm
  • Lancashire and Ireland
Re: Rear Brake Pads
« Reply #24 on: 29 May 2013, 14:20:01 »
Thanks for all the advice.
Did the pads today as it was a nice day for once.
I would strongly advise the use of a proper punch to remove the pins and not a nail.
However both of the springs were missing! Is it vital they are fitted and what is there function. I will get a set as the pins were very rusty anyway but until I do can someone advise.
Thanks
Re: Rear Brake Pads
« Reply #25 on: 29 May 2013, 16:24:55 »
I've told Mark in the past ......  ::)  ;D
http://images.omegaowners.com/images/guides/servicing_rear_brakes/IMG_0523.jpg
Which springs? There's just the sprung anti rattle clip on top of the pads.  :-\
Re: Rear Brake Pads
« Reply #26 on: 29 May 2013, 18:29:38 »
They are antirattle only I think, but I would feel uncomfortable if they weren't there. But should be OK to drive around until you get some
Re: Rear Brake Pads
« Reply #27 on: 29 May 2013, 19:57:37 »
Until replaced mine, it was more of a token gesture towards anti-rattling  ;D There wasn't much left.  :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Rear Brake Pads
« Reply #28 on: 29 May 2013, 20:30:54 »
Your comments about vented rear discs and solid rear discs has me worried. I have just replaced my worn vented discs (2003 3.2 Omega) with new pattern solid discs. Is there a risk of the pistons coming out of the cylinders when the pads are worn?
Re: Rear Brake Pads
« Reply #29 on: 29 May 2013, 20:36:57 »
I believe so,yes. ;)
Pages: 1 [2] 3 4  All   Go Up
