Pages: 1 [2] 3  All   Go Down
Author Topic: starting problem  (Read 11020 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
Re: starting problem
« Reply #15 on: 26 May 2013, 09:59:27 »
Oh what does that mean then?
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Toledodude1973
  • IPSWICH U.K.
« Reply #16 on: 26 May 2013, 10:05:21 »
spanner light and engine light both flash together and cant get car to start at all today .Could be a bit flooded after my pedal attempts i guess
Big_Al
« Reply #17 on: 26 May 2013, 10:07:20 »
not sure on that one . should only be spanner light that flashes .Someone will advise .
Big_Al
« Reply #18 on: 26 May 2013, 10:45:37 »
PM sent
« Reply #19 on: 26 May 2013, 14:00:58 »
Immolbliser? ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #20 on: 26 May 2013, 15:34:32 »
Thanks dbug tried spare key as well but no joy. Going to get codes read if  i can start the car any other ideas greatly received
symes
  • oxford
    • R reg 940 volvo
« Reply #21 on: 26 May 2013, 16:18:22 »
terminal connectors by battery-the contacts inside work loose-unplug them and close up connectors a little-mine did same-spanner/eml and also got occasional Gearbox check-on mid :y
« Reply #22 on: 26 May 2013, 17:03:59 »
Never seen those connections work loose, must have clocked up over 250k over the years with all our Omegas, never opened fuse box on some of them!
Gearbox fault? What's the relevance here? Nothing to do with engine bay fuses  ???
No joy as in not starting? Double check basics make sure the transponder is in the key, but sounds like you need a code reader.
Might be worth dropping a PM to Elite Pete or DarthLooKnee they maybe able to assist  :y
« Reply #23 on: 26 May 2013, 17:24:48 »
 :y First check to fix or eliminate (remember its for free!!) ;)
mmcg
« Reply #24 on: 26 May 2013, 19:57:04 »
My  z22xe is not driven much since I got the dti,if the battery is any bit down that spanner light flashes . It will only start with a jump start .
Toledodude1973
  • IPSWICH U.K.
« Reply #25 on: 26 May 2013, 20:06:00 »
yep i'll have wait to read  codes bit awkward now car wont start, also noticed something else strange rear passenger side window has somehow opened itself twice since starting problem.....any connection?thanks again forall help
Toledodude1973
  • IPSWICH U.K.
« Reply #26 on: 27 May 2013, 10:10:33 »
Tried car this morning and actually started after 6-7 attempts, warning light car/spanner now stays on with car running smoothly -any ideas?
Toledodude1973
  • IPSWICH U.K.
« Reply #27 on: 27 May 2013, 15:06:30 »
Lazydocker very kindly came round with code reader,nothing came up only throttle faults after disconnecting plug socket and reconnecting again to throttle body.
When ignition is switched on the throttle body butterfly valves chatter and unable to start car,can anyone help with this thank you
symes
  • oxford
    • R reg 940 volvo
« Reply #28 on: 27 May 2013, 18:38:43 »
need new throttle body as said by me after your first post ;)
Toledodude1973
  • IPSWICH U.K.
« Reply #29 on: 27 May 2013, 19:14:04 »
I gave it a clean both sides ,maybe a more thorough effort neded will try tomorrow thanks Symes
Pages: 1 [2] 3  All   Go Up
