Author Topic: omega elite stereo info  (Read 2849 times)
megaelite
    • a car
« on: 25 May 2013, 23:32:04 »
i think in the omega i have just bought its has the ncd2006 stereo but it keeps playing up, what other bose stereo can i fit in it
Re: omega elite stereo info
« Reply #1 on: 26 May 2013, 00:15:26 »
CCR2006. What problems are you having ???
megaelite
    • a car
« Reply #2 on: 26 May 2013, 00:34:58 »
randomly turning itself on, keeps going from cd to tuner without me touching it and the volume button only works when it wants to, can i remove it and replace it with a ncdc2013???
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #3 on: 26 May 2013, 01:33:19 »
I would try a reboot by removing it first in case there's something loose, or a problem with the fascia connections. Might be something totally different of course!
Other than that replace it with a known working 2006 unit. You could go down the NCDC route but you'll need to replace the screen as well, and they have their own issues.
Sorry if you know that  :-X
megaelite
    • a car
« Reply #4 on: 26 May 2013, 10:34:34 »
the stereo was removed just before i bought it to be recoded and re-fitted the day i got the car, is there another omega bose unit that will fit without having to change the screen as the one in my car is a tape player and 4 cd and i just think tape players are a bit naff. tia
« Reply #5 on: 26 May 2013, 10:55:02 »
CDR2005. But thats even more naff.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #6 on: 27 May 2013, 02:39:50 »
As TB says the 05 will give you strictly single cd. The 06 is what I have and I think gives the best of both worlds. The 4 cd gives a selection, and I use a cassette adaptor to play iPhone through the stereo. If you're looking for a fancy modern unit, then an Omega is not the right source, particularly with BOSE.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #7 on: 28 May 2013, 14:40:28 »
Wouls have thought the easiest solution would be to fit another CR2006 or look into retro fitting a NCDC and change the Screen, some additional wiring required (both need to be Bose version from another Elite) if you want to retain the current fitment and look.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 28 May 2013, 14:46:51 »
I quite like my 2006, means i can play my old mix tapes instead of them new fangled disc thingys ;D
Hoof'land storeman.
