Pages: 1 [2] 3  All   Go Down
Author Topic: Rear brake pad clip  (Read 4955 times)
Re: Rear brake pad clip
« Reply #15 on: 02 June 2013, 21:58:35 »
Hi last 3 sets of genuine rear pads I bought for black beauty came with new pins and clips in box along with pads to suit solid discs cheers eric
Oh really? That a pad set, recall rear pads are dirt cheap, around £10? As I did buy some myself a year or so back, they never came with new pins though  :(
I suspect we're talking 'the real deal' vs Trade Club pads.  ;) I've never had a set of pads come with pins and/or clips either, mine have all been TC
« Reply #16 on: 02 June 2013, 22:00:16 »
Must be, as recall little fatty mentioning pins were expensive and worth re-using unless they've really had it.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #17 on: 02 June 2013, 22:00:33 »
I am learning all the while. I suppose the pins are different for vented and unvented too. I did check my spare pair of rear calipers and they are the same width as the 3.2 vented caliper. I have not checked my 2 litre calipers. Is it the case that all V6 cars have ventilated rear discs and all 4 cylinder cars have solid rear discs?
« Reply #18 on: 02 June 2013, 22:01:59 »
Vented only on 3.2, maybe 2.6? Ca't remember.
Very early 2.0, think pre 1996 had smallers front discs, but all other Omega's V6/Diesel/4pot all have same disc and pad size all around  :y
« Reply #19 on: 02 June 2013, 22:03:39 »
Yes. As, you've discovered, the vented disc's calipers are wider, hence a longer pin required.
.... Is it the case that all V6 cars have ventilated rear discs and all 4 cylinder cars have solid rear discs?
No.
Vented discs are fitted to the rear of DBW V6s  :y
    • 530D M Sport, 330i Coupe
« Reply #20 on: 02 June 2013, 22:07:31 »
The OEM pads come with them but the Tradeclub ones don't.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #21 on: 03 June 2013, 09:17:32 »
recently purchased Pagid rear pads no clips or pins included.
« Reply #22 on: 03 June 2013, 11:03:09 »
Assuming Black beauty is your 3.2 estate I hope to God you didn't fit them :-\
Last time I bought all the bits, they came to £20 ish :-\ pads are available from £8 up and are the same as Carlton/Senator, although the £15 for TC pads is pretty good imho :y
The issue with the clips is tha eventually the rivets rot out and the the clip just falls apart. Prudent to change them every 2 or 3 pad changes on condition.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #23 on: 03 June 2013, 15:01:55 »
Just go to local factor new pin set inc rattle plates bout £11.00 :y
Hoof'land storeman.
« Reply #24 on: 03 June 2013, 15:28:11 »
£8  :P :y
« Reply #25 on: 03 June 2013, 15:32:30 »
;D if only it were that simple...
My excuse for a factors only supply Apec fitting kits, and apparently they don't make the vented kits... :-\
biggriffin
« Reply #26 on: 03 June 2013, 16:39:12 »
My local CAS supply both types as long as you tell them. :)
Hoof'land storeman.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #27 on: 03 June 2013, 17:11:30 »
ECP provide both for dirt cheap... just be sure to stress to the retarded monkey sales assistant whether you have vented or solid  :y
RIP Paul Lovejoy
omegapioneer
  • Omagh Northern Ireland
    • 97 2.5td Elite auto
« Reply #28 on: 13 June 2013, 08:04:57 »
HI no the pads and pins were for the wifes 3.0 elite black beauty, as mine is very krypton green, but thanks for the concern, Eric
Vx trade club card holder
« Reply #29 on: 13 June 2013, 20:08:34 »
Yeah, but I insist that the left pedal does something useful, hence am a tad picky on using cheap crap pads.
Pages: 1 [2] 3  All   Go Up
