Author Topic: Air Bag Warning Light  (Read 2408 times)
m.ian
« on: 05 June 2013, 06:48:21 »
After removing the drivers door card the air bag warning light has come on.
As there is no air bag in the door, is this connected or do I have another problem?
mav1508
  • surrey
    • 2.6 MV6 saloon
Re: Air Bag Warning Light
« Reply #1 on: 05 June 2013, 06:57:05 »
did you unplug the door connector with the ignition turned on...? i had this problem with my old 2.5 elite, i was trying to fix a window problem and disconnected the door plug with ignition turned on thus ending up with the airbag light on :'( :'(
m.ian
« Reply #2 on: 05 June 2013, 07:25:28 »
unplugged the window switches but nothing else  :(
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #3 on: 05 June 2013, 07:32:12 »
hmm. ??? strange i had my door card off and window switches out with ignition on and no lights.????
from what ive been told on here if the door connector is unplugged this can throw up the fault with the airbag...
« Reply #4 on: 05 June 2013, 07:40:35 »
There's no air bag in the door, but he sensor for the side airbag in the side of the seat is, it's at the rear of the door at the bottom. You've disturbed the wiring for it & then turned the ignition on if all was well before hand.
You need someone to turn to warning light off for you, the SRS is the only warning light that doesn't self re-set after the fault has been fixed.
« Last Edit: 05 June 2013, 07:44:32 by Andy B »
mav1508
  • surrey
    • 2.6 MV6 saloon
« Reply #5 on: 05 June 2013, 07:43:11 »
[/quote
this was the information i got from the members last time this happened
Re: passenger window...
« Reply #8 on: 28 December 2011, 17:02:11 »
Looks like your car has side airbags. (just checked, its a W plate so will have) You either had the ignition switched on when disconnecting or switched it on whilst disconnected, hence the airbag fault showing.
The door has impact sensors within detecting sudden compression of the panel which activates the side airbags on the seats.
m.ian
« Reply #6 on: 05 June 2013, 07:55:32 »
damn must have had the ignition on then.  >:( >:( >:(
Still only disconnected the window switch so confused.
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #7 on: 05 June 2013, 14:07:01 »
could pop it here ian, or wait till i come over my dads in tamworth at weekend, will turn it off for you
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
m.ian
« Reply #8 on: 05 June 2013, 15:25:41 »
that would be great if you could  :D :D :D
