Author Topic: Misfire  (Read 2465 times)
animal65
  • SWINDON
    • VAUXHALL OMEGA ELITE 3.0
Misfire
« on: 06 June 2013, 11:50:36 »
Ok so car eventually passed MOT tester says car running very clean emissions it sailed through drove out of the mot station and now im only firing on 4 cylinders should be 6 keeps misfiring plugs have done a maximum 20k checked all and cant seem to see anything obvious this is was an intermittent fault now constant
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Misfire
« Reply #1 on: 06 June 2013, 11:53:25 »
Do the paper clip test(howto in maintenance section) and see what codes flag up,my money is on coil pack failure :-\
other rides
animal65
  • SWINDON
Re: Misfire
« Reply #2 on: 06 June 2013, 11:58:23 »
do you have a link im no good with technology lol
henryd
  • west cornwall
Re: Misfire
« Reply #3 on: 06 June 2013, 12:03:45 »
other rides
Re: Misfire
« Reply #4 on: 06 June 2013, 17:01:04 »
+1 :y :y
Re: Misfire
« Reply #5 on: 06 June 2013, 17:38:10 »
Although the paperclip test wont throw up a fault for a duff coil pack. ;)
It will rule all sorts of other things in or out though. :y
henryd
  • west cornwall
Re: Misfire
« Reply #6 on: 06 June 2013, 21:50:45 »
Yes I realised that but thought it was worth checking for owt else :y
other rides
Re: Misfire
« Reply #7 on: 06 June 2013, 22:09:32 »
Yep. :y
Re: Misfire
« Reply #8 on: 07 June 2013, 07:46:13 »
Paperclip it, if no fault codes, suspect HT side, as suggested above.
animal65
  • SWINDON
Re: Misfire
« Reply #9 on: 08 June 2013, 10:14:08 »
it is the coil pack
symes
  • oxford
    • R reg 940 volvo
Re: Misfire
« Reply #10 on: 08 June 2013, 11:59:32 »
it is the coil pack
are you sure?  most miggy's I encounter-its lead breakdown not coil pack-usually because they been fitted with cheap leads-which dont last
Re: Misfire
« Reply #11 on: 08 June 2013, 15:57:44 »
it is the coil pack
2 cyls lost = coil pack ;)  Same as on my old Elite
Page created in 0.038 seconds with 21 queries.
