Author Topic: Project "No Fear" out of operating theatre- alive!  (Read 1516 times)
« on: 17 May 2008, 20:27:14 »
Makie and me spent the whole of today putting the 2.0 engine back together.
Progress was slow due to silly little snags, but we got there in the end.
He cleaned the block, while I fitted the exhaust manifold and DIS etc to the head. We then lifted the head on, and went from there.
He then started getting the inlet manifold and throttle body and all those gubbins on, while I did the cambelt, aux belt etc.
I was a bit concerned about the cheap nasty pattern head bolts, but I didn't break one !
When I filled up with coolant we had a leak. Mirror showed it to be coming from the stat housing, so we ditch the ill fitting pattern seal, and use the original one with some sealant. Job done!
When we worked out the firing order, on with the leads and turn the key.
She fired up first time and ran on all 4 which was excellent.  :y
I'm also pleased to report that there is now no more pressurising of the coolant system and the smell of petrol isn't coming through the header tank, so the skim and new head gasket seems to have cured the problem!
The EML was on before the strip down, and despite everything being confirmed as being plugged in correctly, was on after.
Quick paperclip has shown 0130 Heated Exhaust Gas Oxygen (HEGO) sensor so I suspect I need to try a different Lambda?
Otherwise, all went well. Tomorrow, I will be doing the ATF and giving it a general service and a good clean, and then get some short term insurance and go for a test drive!
(Maybe over to Tech2 land  ::)  ;D )
Re: Project "No Fear" out of operating theatre- alive!
« Reply #1 on: 17 May 2008, 20:30:16 »
Well done the pair of you ... a good days work   :y :y
So the project is on time and within budget ??? and I thought you worked for the government .. that never happens !!!
 ;D ;D ;D ;D
waspy
« Reply #2 on: 17 May 2008, 20:30:33 »
Job well done James & Markie.
It's allways good to do something yourself instead of at a garage, because you stand back proud of what you've done  :y :y :y
Debs.
« Reply #3 on: 17 May 2008, 20:31:21 »
 :y Remarkable progress chaps!.....well done; `looking forward to piccies (please)  ;)
« Reply #4 on: 17 May 2008, 20:33:59 »
well done fellas :y
« Reply #5 on: 17 May 2008, 20:34:37 »
Anything specific?  :)
waspy
« Reply #6 on: 17 May 2008, 20:37:48 »
You ::)
file28
« Reply #7 on: 17 May 2008, 21:03:17 »
glad to hear it's all working for you, have been reading the story so far  :y
Debs.
« Reply #8 on: 17 May 2008, 21:05:02 »
Rebuilding/reassembly shots (generally) if poss.?  :y
bertiecbx550
« Reply #9 on: 17 May 2008, 21:12:20 »
 :o :o shock and horror as govt lead project comes in ahead of schedule and under proposed budget!!!  ;D ;D nice one james good to see you back mate enjoy the fruits of your labour... :y
markey mark
  • SLady bitshorpe north lincs
« Reply #10 on: 17 May 2008, 21:36:17 »
great work chaps !! :y
Big Fra
  • Motherwell
« Reply #11 on: 17 May 2008, 22:06:57 »
Good stuff chaps, as soon as I get a driveway, I'll be doing more of the same, probably less fixing and more breaking though. :y
Yeah, sum piccies would be great if possible.
Martin_1962
« Reply #12 on: 18 May 2008, 10:11:12 »
Good job  -are you gassing it?
geoff
  • thornaby,stockton on tees
« Reply #13 on: 18 May 2008, 10:13:36 »
well done good job m8y 8-) 8-) 8-)now have a well deserved beer 8-) 8-) 8-)
« Last Edit: 18 May 2008, 10:13:48 by geoff »
MikeDundee
  • Costa Del Peckham
« Reply #14 on: 18 May 2008, 10:18:58 »
keep up the good work James :y
