Author Topic: Door check strap  (Read 3706 times)
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: Door check strap
« Reply #15 on: 09 June 2013, 15:47:12 »
I don't know about the parts as I made the repair played myself for one door as I didn't know you could buy them then, it was years ago. When the other door started to go last year all I did was weld the door up where it had started to split. I know the bits are cheap, but welding was a lot quicker and easier as it wasn't badly gone.
Al
If it aint broken, you aint trying hard enough
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #16 on: 22 June 2013, 14:02:55 »
Have had the same noise on drivers door for some time.Just replaced the plastic washer 75P at the support end and noise gone.However I noticed that the support is starting to come away from the body is there any problem with braising or welding in this area.Can pop rivets be used to repair in this area.Have I read about repair plates.
Simon.rose1
  • Walsall
    • Omega 2.5v6 cdx
« Reply #17 on: 22 June 2013, 14:50:08 »
Mine has now ripped out the door so hopefully I can still get the repair panel on without to much hassle but not had the time to do it or if I can get the panels to fit
