Author Topic: Wishbones and Drop Links  (Read 5456 times)
Re: Wishbones and Drop Links
« Reply #15 on: 15 June 2013, 11:59:54 »
40 Jc 10 slip onto dual towards Brackley? Often leave Cruise set at 80 until completed slip road turn, often fly past braking BMW's and such.
Why slow down so early? You only need to knock about 30-35mph off for the roundabout, not need to ease off until at said roundabout  ???
From what I'm hearing, your mum drives faster than you - ironic really, considering what she says ;D
I don't slow just leave cruise set until I have to brake, I had my old Senator vary sideways there, at a rather slow speed too  ;D
« Reply #16 on: 15 June 2013, 12:11:57 »
Rarely use cruise on motorways, just not possible on UK ones :(
It was a Senator, or course it went sideways, thats what they did. Most of those weird handling triats were fixed for the Omega, though I've always said they went overboard, and dialled in too much understeer.
The camber on that roundabout has the potential to catch you out (doesn't it, Mrs chrisgixer ::)), so thats why I say 45-50 is tops around there...
« Reply #17 on: 15 June 2013, 12:12:42 »
And the next 3 roundabouts are often slippery as well, so caution is advised.
« Reply #18 on: 15 June 2013, 12:14:14 »
720 spin at Esso garage  ::)  :-X
« Reply #19 on: 15 June 2013, 12:16:17 »
Can't match that, young jedi, only ever had wiggles there, usually when I least expect it.
In fact, I don't think I've ever had an Omega facing the wrong way. Clearly not trying hard enough.
« Reply #20 on: 15 June 2013, 12:18:28 »
Got too cocky with the Senator after dropping Max off that night there was major surgery on this V6. It was absolutely soaking, plus oil on the ground. That's my excuse anyway  ::)
« Reply #21 on: 15 June 2013, 12:19:10 »
Don't believe that for a second ;D although the Bullet has both working suspension and decent tyres ::)
    • 530D M Sport, 330i Coupe
« Reply #22 on: 15 June 2013, 12:41:28 »
M40/M25 slip is another one, cruise left on, 90% I always catch someone on that slip road turn.
Yep you'll soon catch someone if they are all stationary on the slip road!
chrisgixer
« Reply #23 on: 15 June 2013, 12:58:13 »
Exactly. If the car is never driven hard enough to to move the front suspension, such as compression under braking, extension under acceleration, body roll in corners, or any combination of, with bumps thrown in. Then the bushes will never move enough to wear out.
I do wonder how Tunster gets round corners. :-\
Is this why my mum's first ever MOT on her current beemer failed miserably of worn suspension components...
Bet it's got about 120k miles on it?
« Reply #24 on: 15 June 2013, 19:10:30 »
And no airfreshner ::)
chrisgixer
« Reply #25 on: 15 June 2013, 23:53:14 »
