Author Topic: Temp gauge not working.  (Read 8679 times)
Vauxhalloofer
  • South East
    • Cdx 2.2
« on: 10 June 2013, 21:44:04 »
Hi everybody, temp gauge on 2.2 is on zero and the top pipe heats up gradually.Was working before, thermostat housing looks like this one
http://www.ebay.co.uk/itm/Vauxhall-Omega-Vectra-Astra-Zafira-Thermostat-Housing-Stat-/290928393510?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43bcaefd26
but it doesnt have a long bit on it, mine has a short pipe lol .Will this one on ebay fit a y22xe 2.2 2001, as when i changed stat before it wouldnt sit right as housing was worn away inside on the lugs.So wedged it .Thats what makes me think that its the stat and not the gauge.Many Thanks  :-\
Re: Temp gauge not working.
« Reply #1 on: 10 June 2013, 22:10:23 »
Check electrical connector is on temp sensor at back of engine ;)
« Reply #2 on: 10 June 2013, 23:23:00 »
Sender unit here. To test the gauge, earth/ground the blue wire from the sender unit & the gauge should show fully hot.
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #3 on: 11 June 2013, 20:54:36 »
yep back of mine does'nt look like the picture. It has 2 wire multi plug, then spade in black sleeve somewhere next to it.I have pulled of spade ran to earth nothing. Now i cant see what it goes back on its so tight behind there. I ve got inspection mirror but at the back all i can see is the multi plug and right next to it a rounded off small plug. Nothing for a single wire spade to go on to. Anyone got pic of 2.2 16v rear Thanks
« Reply #4 on: 11 June 2013, 21:03:56 »
Spade connector slides over the round disc at the top of the sender
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #5 on: 11 June 2013, 21:07:01 »
Wicked, so that smaller plug must be it. I take it it slides downwards from the top so as to keep it there.Odd connection lol
« Reply #6 on: 11 June 2013, 21:13:39 »
Slides in from which ever way you want to ...... it's circular  ;)
Pretty sure all my Vauxhalls over the past 20 odd years have been the same  ;)
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #7 on: 11 June 2013, 21:32:11 »
Nice one got it back on, still no change on gauge in car, surely it must be that stat was all working ok the other day and as i said i bought a new stat to put in a while back, on fitting it i realised that it was too small in the lug length to sit in the housing so i put part of old one on top of lugs to hold it in.Maybe its stuck its the only thing ive touched, so will this housing fit a 2.2 z22xe.
« Reply #8 on: 11 June 2013, 21:50:20 »
Yes that's the correct one but this one is cheaper and no better/worse! :y
http://www.ebay.co.uk/itm/Vauxhall-Calibra-VX220-Vectra-Omega-1-8-2-0-2-2-Thermostat-Housing-90501081-OEQ-/330886217369?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4d0a5afe99
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #9 on: 11 June 2013, 21:58:53 »
Will swap housing and stat then take it from there i think :y Thanks
« Reply #10 on: 11 June 2013, 22:03:51 »
I have pulled of spade ran to earth nothing.  .....
Assuming your ignition was on when you earthed the blue wire, if you didn't get any movement on the gauge you have a fault somewhere ie the gauge itself, or wiring up to it.  :-\
symes
  • oxford
    • R reg 940 volvo
« Reply #11 on: 11 June 2013, 22:45:32 »
most likely cause is the spade on end of wire-changed about 4 so far this year alone ;)
« Reply #12 on: 11 June 2013, 22:50:30 »
maybe ..... something's amiss.
What does anyone do to a spade connector to make it need to be changed?  ??? The one on my car is OE & is 13 yr old  ;D
« Reply #13 on: 11 June 2013, 23:40:38 »
You'd be surprised ::)
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #14 on: 12 June 2013, 00:17:38 »
Had a couple of gauges stop working on my 95 mig. had to replace dash. :'(
