Pages: 1 2 3 4 5 6 [7] 8   Go Down
Author Topic: Front tracking  (Read 17921 times)
  • Auckland
    • Mazda MPV
Re: Front tracking
« Reply #90 on: 16 June 2013, 20:54:11 »
https://www.dropbox.com/sh/f6kx9dg8ujqxp7t/jjxhb6lONv
That works :y
(I still wouldn't support my car by the wishbones though)
« Last Edit: 16 June 2013, 20:57:35 by Andy H »
sassanach
  • trowbridge
Re: Front tracking
« Reply #91 on: 16 June 2013, 20:59:42 »
i would'nt bother with the wood ;D :y
chrisgixer
Re: Front tracking
« Reply #92 on: 16 June 2013, 21:02:19 »
Not as bad as I imagined, but IMO don't jack on the wb. Not worth the risk.
I wonder how the ride height compares with car on the ground, any measurement taken? Wheel to top of wheel arch?
I'd expect it to ride higher...?
sassanach
  • trowbridge
Re: Front tracking
« Reply #93 on: 16 June 2013, 21:04:10 »
and ive lost count of the vehicles ive jacked up on the diff without repercussions,including my mig ;D :y
chrisgixer
Re: Front tracking
« Reply #94 on: 16 June 2013, 21:05:06 »
That you've noticed. ;)
Where's that pic of TB's dif bushes....
sassanach
  • trowbridge
Re: Front tracking
« Reply #95 on: 16 June 2013, 21:06:43 »
true :y
chrisgixer
Re: Front tracking
« Reply #96 on: 16 June 2013, 21:45:59 »
These are TuBys sub frame to body bushes, they sit directly behind the dif, and are the ones that are unbolted to drop the subframe to change the springs.
The top one is completely separated, bar a strand of rubber. The centre alloy bit that's come out, is bolted to the subrafame which is then bolted to the dif.
If the car is raised by jacking on the dif, the entire weight of the car is acting to pull the alloy block away from the cup/u shaped bracket, and rip the rubber apart.
These had done 170k miles and gave a "loose rear end feal" iirc. They have not been forced apart by jacking on the dif to raise the car in this instance, as it was noticed some time before that the slloy had gone furry and oxidised, this had eaten into the rubber to alloy bond and they had separated.
Jacking on the dif will apply forces that want to lift these out of the cup. ;)
Re: Front tracking
« Reply #97 on: 16 June 2013, 22:05:53 »
Here's that pic -
chrisgixer
Re: Front tracking
« Reply #98 on: 16 June 2013, 22:17:13 »
And those discs have had it btw. :(
Re: Front tracking
« Reply #99 on: 16 June 2013, 22:18:37 »
Yup exactly like MotherT's fine in outside I bet, and top edge inside, but feked at the bottom.
Re: Front tracking
« Reply #100 on: 17 June 2013, 19:51:42 »
They all seem to go like that, no idea why...
Re: Front tracking
« Reply #101 on: 17 June 2013, 19:53:58 »
Tight as a duck's backside now, but I reckon replacing those and the poly doughnuts have trashed what I can get out of rear tyres. Then again, RT's were never gong to be durable  :'(
chrisgixer
Re: Front tracking
« Reply #102 on: 18 June 2013, 00:54:18 »
Iirc, I reckoned the splash guard is short at the bottom. :-\
And you rekoned the caliper twists away under heavy breaking...? :-\
If the rust eats in from the edge, as it looked on mine...why not both sides?
...in both cases, why doesn't it do it on both sides..? The splash guard would get the edge wet of both faces, although the face is slightly exposed inboard.
If the caliper twists, then the inside radiuos of the outboard face would suffer too.
Dunno either. :-\
chrisgixer
Re: Front tracking
« Reply #103 on: 18 June 2013, 01:05:50 »
So you suspect less miles from the rears...?
Might well be, the rear has less opportunity to articulate with poly rears. So gives a tighter turn in feel, less slop. But, the rears are not following the same radius as well as oe bushes. (Think four wheel steering, effectively. )
I must say though, the confidence on turn in is much improved. Especially on poor surfaces/worn Tarmac on higher speed corners :y
chrisgixer
Re: Front tracking
« Reply #104 on: 18 June 2013, 02:25:08 »
Actually, I suspect the extra confidence is the problem there. ;D
Pages: 1 2 3 4 5 6 [7] 8   Go Up
Page created in 0.012 seconds with 14 queries.
