Author Topic: coolant leak ? water pump - pics & questions!  (Read 4762 times)
Re: coolant leak ? water pump - pics & questions!
« Reply #15 on: 16 June 2013, 20:12:54 »
Hi dbug,i just wanted to say how nice it was of you.To sort this mans pics out,thats what i love about OOF nice people like you.Regards Dean :) :y
Well thanks for that mate - much appreciated :y  No probs to sort out guys pics if you know how ;)
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #16 on: 18 June 2013, 12:53:37 »
Brill info,on the question of engine flush,would it be better to use "cheap" oil to run through a couple of times and then fill up with the best oil? (In the context of mayo in the engine after HG failure)?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #17 on: 18 June 2013, 15:39:47 »
Yes,a couple of short changes probably better than using engine flush :y
other rides
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #18 on: 18 June 2013, 17:26:46 »
Thanks geez!
Got to get to that point yet....lol
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #19 on: 18 June 2013, 18:47:51 »
worth a bottle of wynns lifter fluid in with the oil if your lifters are tap tap tapperty :)
RIP Paul Lovejoy
Paulus62
  • Llanfairfechan. North Wales
    • 2001 2.6 Estate Manual
« Reply #20 on: 19 June 2013, 13:16:27 »
Do you add the wynns lifter fluid to the first oil change or second? And how long do I run the engine with the first new oil before changing it?
Webby the Bear
  • Northampton
« Reply #21 on: 19 June 2013, 13:22:05 »
if the lifters are tapping I BELIEVE it should go like this:
change oil
300 miles later change oil again and add Wynns
change oil again in normal 3k miles.
anyone concur?
RIP Paul Lovejoy
