Sunday drive horseshoe pass...
Started by Mr.OmegaMan, 16 June 2013, 19:04:09
Quote from: tunnie on 22 June 2013, 15:52:52
Motorway/Dual Carriageway run, normally only get about 27 out of it over the course of a tank.
Bloody hell :o
Quote from: tunnie on 22 June 2013, 16:04:08
High revs and heavy braking is what kills it
Ah, that explains it...
Mr.OmegaMan
Quote from: TheBoy on 17 June 2013, 08:24:17
Quote from: OmegaMan2.2 on 16 June 2013, 21:16:36
Oh forgot to add Instant mpg while climbing the hoseshoe pass was around 4 - 6 mpg going a reasonable speed engine temp got up to between 90-95c its one hell of a climb  :o
Sure your display is properly programmed - GM put a lower limit of 7.1mpg on the display so as not to scare people ;D
Yep my mistake must have been looking at something else  :-[
Tested it today sports mode and the kickdown switch floored it stopped at around 7. Something couldn't keep an eye on it at those speeds on the twisties ;D
Quote from: OmegaMan2.2 on 30 June 2013, 19:04:06
Have you tried it in 2nd in sports and floor it  :o
Mr.OmegaMan
Quote from: Emd on 30 June 2013, 21:34:49
Can't say I use the manual 1,2,3 gears... What's the performance difference by putting in second with sports then surely not faster than in Auto with sports on with kickdown switch floored  :-\ will just have to give it a go sometime then  :D
Quote from: OmegaMan2.2 on 30 June 2013, 21:38:57
1 mpg  ;D ;)
Mr.OmegaMan
Quote from: Emd on 30 June 2013, 23:07:49
1 mpg  ;D ;)
;D Wouldn't be surprised.
