White Dials
Started by RobG, 18 June 2013, 19:11:58
plym ian
Nice job, looks great. We're they easy to fit? Also do you have a website link for them quite fancy doing that to my one :y
chrisgixer
Quote from: RobG on 18 June 2013, 19:38:27
Quote from: pletis143 on 18 June 2013, 19:29:09
where did you pick them up from rob.
Only available from the States
Rrrrravin iiiit? ;D
Where's the warning lights...? :-\
And why in the states...? Thought they only got the v engine in the catera...? :-\
Look ok actually. Needs a few more digest on the speedo. ::)
pauls
Not for me; black dials with white numbers and needles are the way to go. And they're standard!
I've just spent £260 on three Smiths Flight gauges for the Avenger, as I've always liked the military spec dials.
I can't see the pictures, just 2 little squares........ ::) ::)
My Jeep has white dials............... :D :D :y
zirk
Looks ok Rob, I have a what looks to be similar White Dialled Dash for a V6 kicking around somewhere, fairly sure there the same.
Apart from the 160 mph bit.  ;)
Quote from: plym ian on 18 June 2013, 20:10:39
PM sent
#23
Quoteblack dials with white numbers and needles are the way to go. And they're standard![/quote]
QuoteI've just spent £260 on three Smiths Flight gauges for the Avenger,
They`re not standard though are they ::)
QuoteWhere's the warning lights
Can be seen if not in direct sunlight, and are easily visible at night with panel lights on.
Quotewhy in the states...? Thought they only got the v engine in the catera
Catera uses the UK 4-pot speedo and tacho
QuoteNeeds a few more digest on the speedo
:P :P ;D
Quote from: RobG on 18 June 2013, 21:58:19
Nope, the Avenger did not have white dials, not even the GT............ :D :D
chrisgixer
Quote from: RobG on 18 June 2013, 22:03:46
:P :P ;D
Yeah, quite like those then. Good job IMO. :)
Quote from: chrisgixer on 18 June 2013, 22:08:41
:P :P ;D
Ta muchly :)
symes
Looks nice mate--but needles are hidden :-\  if needles were a different colour-so could be seen quickly-would be better IMO
Quote from: symes on 18 June 2013, 22:21:11
Will be done when paint arrives ;)
