Pages: 1 [2] 3 4 5 6 7 8 9 ... 18   Go Down
Author Topic: cam gasket  (Read 60279 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: cam gasket
« Reply #15 on: 04 July 2013, 11:36:45 »
Whats up now ralf  :-\
your gonna need a new pair of bonnet hinges next  :y ;D
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #16 on: 04 July 2013, 13:52:32 »
i just wish i hadn't started on the cam gasket mate . till i done it no problem  >:( >:(
Re: cam gasket
« Reply #17 on: 04 July 2013, 14:10:10 »
Is it still smoking  :(
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #18 on: 04 July 2013, 16:26:34 »
no cleaned throttle body again . not doing it now . doing an oil change on weekend  :y :y
Re: cam gasket
« Reply #19 on: 05 July 2013, 11:01:44 »
Wish mine was a quick fix like that   :( What did you do to stop it smoking  :-\
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #20 on: 05 July 2013, 13:32:22 »
no i didn't fix it took it for a run today and on way back got smoke again. cant figure it out do a cam gasket it starts to smoke . before i done cam gasket no smoke . so figure that out  >:( >:( >:(
Re: cam gasket
« Reply #21 on: 05 July 2013, 13:36:49 »
Smoke out the exhaust means its burning a fluid of some kind, in cold weather due to the size of the exhaust system on the Omega, it can "smoke" fair bit in the cold mornings, but this is nothing more than moisture from the system burning off as it heats up.
In this hot weather we have currently, plus you say its on the return journey means the exhaust is up to temp, so its burning something.
Grey-ish/White tint to smoke = Water/coolant
Blue-ish/dark tint to the smoke = Oil
Look very closely and monitor the coolant & oil levels.
Steve B
  • Leicestershire
Re: cam gasket
« Reply #22 on: 05 July 2013, 13:41:34 »
ralf. why did you do everything that way round  ie;
cam gasket
breathers
oil change
Dont you think breathers should be first   ???
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #23 on: 05 July 2013, 14:22:27 »
you can smell its oil .losing no coolant at all  :y :y
Steve B
  • Leicestershire
Re: cam gasket
« Reply #24 on: 05 July 2013, 14:24:04 »
So is it burning oil ralf
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #25 on: 05 July 2013, 14:25:20 »
but only now and again . and only since i done cam gasket ??? ??? and doing oil change now because i changed gasket
« Last Edit: 05 July 2013, 14:27:25 by bored bigyin54 »
bored bigyin54
  • south wales
    • black beast
Re: cam gasket
« Reply #26 on: 05 July 2013, 14:31:03 »
just cant figure out why its doing it now and not before i changed the gasket
Re: cam gasket
« Reply #27 on: 05 July 2013, 14:38:55 »
Inspect plug wells & remove them checking for oil
Re: cam gasket
« Reply #28 on: 05 July 2013, 14:46:47 »
Is it just burning residue spillage off from the cam gasket  :-\
Re: cam gasket
« Reply #29 on: 05 July 2013, 14:51:01 »
Any oil down the plugs would be quite quickly burned off, within first few miles.
I know that from dropping a load of oil down the 3.0 V6 plugs, from a cam gasket. Clouds of smoke on start up but soon goes!
Pages: 1 [2] 3 4 5 6 7 8 9 ... 18   Go Up
Page created in 0.034 seconds with 20 queries.
