Whats that then
Started by omega3000, 12 July 2013, 00:05:15
Quote from: Emd on 13 July 2013, 20:56:03...
Its a lot easier to get to than the omega andy  ;)  ....
Forgot you weren't in an Omega .....  ;D ;D
Quote from: chrisgixer on 13 July 2013, 22:14:13
Why, if you didn't want an omega due to cost and faults, did you go and buy a similar and reputably less reliable car, with similar parts to the one just sold?
Remember, Oof is in the fortunate poition only concentrate on one model of one manufacturers range of cars. Not all cars have a heater by pass valve. So a factors is even less likely to know (Andyc aside) than a Vx dealer parts man who. They often ask the same question when hearing the letters hbv, ime.
What are the odds of getting a genuine part from a factors though, would you say?
Because the 3.0 omega was falling to bits remember  ;D Rot in the front chassis rails and rear arches plus the running costs and lifters that needed replaced and rear suspension knackered . I had no idea that valve stem seals were an issue on some vectra B's , i had 2 before and never had any issues with that before . If money wasnt so tight i would have another omega but until then ill make do with what i have for now and fix what needs doing bit by bit .
I would have thought any car parts shop would know what a heater valve was and could get one , seems not apart from online stores where you can get anything you need .
chrisgixer
#17
Quote from: Nick W on 13 July 2013, 22:34:44
Remember, Oof is in the fortunate position only concentrate on one model of one manufacturers range of cars. Not all cars have a heater by pass valve. So a factors is even less likely to know (Andyc aside) than a Vx dealer parts man who. They often ask the same question when hearing the letters hbv, ime.
Or, it leads to reactions to simple questions that are pure dogma. Just mention HBV, oil, plugs or other simple service stuff, and it's like Captain Flint has got on the internet("pieces of genuine GM plugs"). The only reason I replaced the £9 HBV on my car with a genuine one was that I managed to snap the vacuum port off the top of it. That would have been much harder to do if I'd spent 4 times as much on it. Oh, and by then I had a spare genuine one on my hotrod engine that won't be needed.
Fixed ;)
chrisgixer
Quote from: Emd on 13 July 2013, 22:43:24
They won't get self levelling shocks either etc etc. pattern hbv's are no better than pattern sensors, going by what i've seen on here. After all the oe ones aren't great, how good can a copy be? (A hypothetical question that, before Nick pipes up ;D )
chrisgixer
Must say I'm getting that ground hog feeling from another thread in this section. ::)
Quote from: chrisgixer on 13 July 2013, 22:45:19
Or, it leads to reactions to simple questions that are pure dogma. Just mention HBV, oil, plugs or other simple service stuff, and it's like Captain Flint has got on the internet("pieces of genuine GM plugs"). The only reason I replaced the £9 HBV on my car with a genuine one was that I managed to snap the vacuum port off the top of it. That would have been [color=red]much harder to do[/color] if I'd spent 4 times as much on it. Oh, and by then I had a spare genuine one on my hotrod engine that won't be needed.
Fixed ;)
Oh, really? it's an 8mm thick, hollow plastic stub. Considering that the pattern part is visually identical to both the one I replaced, and the spare that I used, right down to the casting flash it's virtually guaranteed that it came from the same supplier.
As I said; dogma.
chrisgixer
Quote from: Nick W on 13 July 2013, 22:59:28
Fixed ;)
As I said; dogma.
8mm thick? :o  A perfect match then. Not! ;D
Steve B
Quote from: chrisgixer on 13 July 2013, 22:53:46
arrrrr your missing ralf  ;D ;D ;D ;D ;D
